· Make sure available subnets exist before performing this task. · A router can be attached to multiple subnets. · To avoid forwarding failures, make sure the network egress of the subnet is uis. |
On UIS Cloud, click Cloud Services on the top navigation bar.
On the UIS-Sec portal of UIS Manager Standard Edition, click Network Services on the top navigation bar.
From the left navigation pane, select Network & Security > Routers.
