On UIS Cloud, click Cloud Services on the top navigation bar.
On the UIS-Sec portal of UIS Manager Standard Edition, click Network Services on the top navigation bar.
From the left navigation pane, select Network & Security > Routers.
Click Create.
Configure the parameters as described in "Parameters."
Click Create.
Basic parameters:
Name: Enter a name for the router.
Firewall: Select a firewall for the router. You can also attach a firewall to the router later. To create firewalls, access the Cloud Services > Network & Security > Firewalls page.
Description: Enter a description for the router.
Advanced parameters:
