For the up-to-date compatibility matrix, see Windows/Linux Compatibility Matrix.
Compatibility with Linux operating systems depends on the kernel version. The Redhat5 series operating systems use the same driver and most Redhat6 series operating systems use the same driver. For a Linux operating system whose kernel is not in the matrix, select a CDP driver with the closest kernel version. For example, you can install the CDP driver for Redhat4.7 x32 with kernel cdp_2.6.9-78.EL.ko on Redhat4.5 x32 with kernel 2.6.9-55.EL.
Table-1 OS compatibility matrix
Category |
Operating system version |
Windows |
Windows Server 2003 X86/X64 |
Windows Server 2008 X86/X64 |
Windows Server 2008 R2 X64 |
Windows Server 2012 X64 |
Windows Server 2012 R2 X64 |
Windows Server 2016 |
Redhat |
Redhat 4.2 i386 (2.6.9-22ELsmp) |
Redhat 4.2 i386 (2.6.9-22.EL.ko) |
Redhat 4.3 i386 (2.6.9-34.21AXsmp.ko) |
Redhat 4.6 x64 (2.6.9-67.ELlargesmp_x64.ko) |
Redhat 4.7 x32 (2.6.9-78.EL.ko) |
Redhat 4.7 x32 (2.6.9-78.ELsmp.ko) |
Redhat 4.7 x64 (cdp_2.6.9-78.EL_x64.ko) |
Redhat 4.7 x64 (2.6.9-78.ELsmp_x64) |
Redhat 5 x32 series (2.6.18-8.el5.ko) |
Redhat 5 x64 series (2.6.18-8.el5_x64.ko) |
Redhat 6.0 x32 series (2.6.32-71.el6.i686) |
Redhat 6.0 x64 series (2.6.32-71.el6.x86_64) |
Redhat 6.2 x32 (2.6.32-220.el6.i686.ko) |
Redhat 6.2 x64 (2.6.32-220.el6.x86_x64.ko) |
Redhat 7.0 x64 (3.10.0-123.el7.x86_64) |
Redhat 7.1 x64 (3.10.0-229.el7.x86_64) |
Redhat 7.2 x64 (3.10.0-327.el7.x86_64) |
Centos |
Centos 6 x32 series (2.6.32-71.el6.i686) |
Centos 6 x64 series (2.6.32-71.el6.x86_64) |
Centos 7.0 x64 (3.10.0-123.el7.x86_64) |
Centos 7.1 x64 (3.10.0-229.el7.x86_64) |
Centos 7.2 x64 (3.10.0-327.el7.x86_64) |
Oracle Linux |
OracleLinux-R6-U3-x64 (2.6.39-200.24.1.el6uek.x86_64.ko) |
Kylin |
Kylin-4.0-1E-desktop_20160401-final-x86_64 (3.16.0-23-generic) |
NeoKylin-Linux-Advanced-Server-6.7 (2.6.32-573.el6.x86_64) |
NeoKylin-sws-3.2(64) (2.6.32-220.2.1.2.ky3.2.x86_64) |
YHKylin-4.2-5-x86_64-server (2.6.32-431.29.2.3.ky3.1.x86_64) |
Suse |
SUSE Linux Enterprise Server 10 SP2 x86 (2.6.16.60-0.21-bigsmp) |
SUSE Linux Enterprise Server 10 SP2 x86 (2.6.16.60-0.21-default) |
SUSE Linux Enterprise Server 10 SP2 x64 (2.6.16.60-0.21-default) |
SUSE Linux Enterprise Server 10 SP2 x64 (2.6.16.60-0.21-smp) |
SUSE Linux Enterprise Server 10 sp3 x64 (2.6.16.60-0.54.5-smp_x64) |
SUSE Linux Enterprise Server 11 SP2 x64 (3.0.13-0.27-default) |
Suse Linux Enterprise Server 11 sp3 x86 (3.0.76-0.11-pae) |
Suse Linux Enterprise Server 11 sp3 x64 (3.0.76-0.11-default) |
Suse Linux Enterprise Server 11 sp3 x64 (3.0.101-0.31-default_x64) |
Suse Linux Enterprise Server 12 sp2 x64 (4.4.21-69-default_x64) |
Ubuntu |
Ubuntu-12.04 x64 (3.13.0-117-generic) |
Ubuntu-14.10 x64 (3.16.0-23-generic) |
