Install MySQL on a standalone server
Standalone MySQL installation procedure
Download a MySQL installation package
  1. Download a MySQL installation package from https://dev.mysql.com/downloads/mysql/ according to your requirements.
Figure-1 Downloading MySQL
  1. Transmit the installation package to the target VM and uncompress it.
Figure-2 Uncompressing the installation package
Uninstall an old MySQL version
Skip this task if your environment does not has an old MySQL version installed.
To uninstall MySQL:
  1. View the MySQL version.
  1. Delete MySQL components in the correct sequence.
Install MySQL components
Execute the following commands in sequence.
rpm -ivh mysql-community-common-5.7.26-1.el7.x86_64.rpm
rpm -ivh mysql-community-libs-5.7.26-1.el7.x86_64.rpm
rpm -ivh mysql-community-client-5.7.26-1.el7.x86_64.rpm
rpm -ivh mysql-community-server-5.7.26-1.el7.x86_64.rpm
Start the MySQL service
  1. Execute the systemctl start mysqld.service command.
  1. Execute the systemctl enable mysqld.service command to enable MySQL to run on startup.
Create a MySQL password
  1. Obtain the temporary password.
  1. Execute the grep 'temporary password' /var/log/mysqld.log command.
[root@localhost ~]# grep 'temporary password' /var/log/mysqld.log
  1. Search for temporary password in /var/log/mysqld.log.
2019-07-06T08:52:01.624650Z 1 [Note] A temporary password is generated for root@localhost: kfyHk8(-Iwo7
kfyHk8(-Iwo7 is the temporary password.
  1. Log in to MySQL with the temporary password.
  1. Execute the [root@localhost ~]# mysql -uroot -p command.
  1. Execute the Enter password:   # command to enter the password.
  1. Execute the mysql> quit      # command to log out.
  1. Execute the following commands to modify the MySQL root password.
mysql> alter user root@localhost identified by 'sdbrk';
mysql> set password for root@localhost=password('sdbrk');
If the password does not meet the password strength requirements, the system displays ERROR 1819 (HY000): Your password does not satisfy the current policy requirements.
To resolve this problem:
1.     Execute the validate_password_policy=0; command to change the password policy.
mysql> set global validate_password_policy=0;    #
The policy requires a password to contain eight or more characters.
2.     Modify the valid password length:
mysql> set global validate_password_length=1;
Query OK, 0 rows affected (0.00 sec)
The minimum password length is 4. If you set the password length to be smaller than 4, the value 4 takes effect.
3.     Modify the password.
mysql> set password for root@localhost=password(' root ');
Query OK, 0 rows affected, 1 warning (0.00 sec)
  1. Enable remote management.
  1. Enable remote access for the root user.
mysql> grant all privileges on *.* to root@'%' identified by ' root ';
  1. Flush privileges.
mysql> flush privileges;
