Configure a vertical extension policy
  1. On the top navigation bar, click Services, and then select DRX > DRX service name from the navigation pane.
  1. Click Vertical Extension Policy.
  1. Configure the CPU and memory parameters, and then click OK.
Parameter
Configure CPU
Select this option to enable the vertical extension policy by CPU usage.
CPU Usage
Specify the CPU usage threshold. The system adds CPUs to a VM when this threshold is reached.
CPUs to Add
Specify the number of CPUs to add for a VM.
Limit
Specify the maximum number of CPUs that can be added for a VM.
Configure Memory
Select this option to enable the vertical extension policy by memory usage.
Memory Usage
Specify the memory usage threshold. The system adds memory to a VM when this threshold is reached.
Memory to Add
Specify the memory size to add for a VM.
Limit
Specify the maximum memory size that can be added for a VM.
