Download a matching NVIDIA graphics driver and upload it to a VM.
Double-click the driver installer and install the driver following the setup wizard.
Restart the VM.
The VNC console is unavailable after you install an NVIDIA graphics driver. Please access the VM through remote desktop software such as RGS or Mstsc. |
Log in to the VM through remote desktop software. Open Device Manager, and then select Display adapters to verify that the model of the attached vGPU is correct.
