Appendix B Install a migration client on a Linux OS
  1. Log in to the migration client through FTP and access the /root/Clone_Client_Linux_64 directory.
  1. Execute the ./install.sh command to run the installation script
  1. Select the matching driver package at the prompt and enter y.
  1. If multiple driver packages exist, select the one that has a similar version as the system kernel.
Figure-1 Installing the migration client
The system prompts install/start CAS succeeded! after the installation finishes.
Figure-2 Installation completion
