For UniCloud Usphere and external CAS, manage VM templates from the left navigation tree on the Resources page.
On the top navigation bar, click Local Resources, and then select an external platform.
Click the VM List tab.
Click More in the Actions column for the target external VM, and then select Clone as Template. Alternatively, click the name of the target VM, click More on the Overview tab, and then select Clone as Template.
Configure the parameters as described in "Parameters."
Click OK.
Click the Template tab.
Click Deploy VM in the Actions column for the target template.
Click OK.
Click Delete in the Actions column for the target template.
In the dialog box that opens, click OK.
Template Name: Enter a name for the template.
Host: Select a host for the template or VM.
