Configure ISLP and security hardening
Information security level protection (ISLP) and security hardening secure the system and its confidential data.
  1. On the top navigation bar, click System.
  1. From the left navigation pane, select Parameters.
  1. Click the ISLP and Security Hardening tab.
  1. Click Edit and then edit the parameters as needed.
  1. Click Save.
For a VM to access the VNC console, you must specify a VNC proxy server when the secure mode or mandatory HTTPS mode is enabled.
Changing the state of root SSH login permission switches the account used for login on all hosts managed by the system. When the system prompts for a password, enter the password of the correct account. If you have forgotten the password, you can enter a new password directly.
