You can configure backup policies to back up VMware VMs to CAS.
Backup policies are executed sequentially. The system can execute a maximum of five VM backup tasks simultaneously, and each host can run only one backup policy task. If the backup task starts later than the configured backup end time, the task will not be executed.
You cannot create backup policies for incorporated VMs of UniCloud Usphere or external CAS.
To ensure successful migration or backup for a VMware VM, make sure the number of snapshots created for it does not exceed 31.
On the top navigation bar, click Resources, and then select External Platform from the left navigation pane.
Click the Backup Policies tab.
Click Add.
Configure the parameters as described in "Parameters."
Click OK.
Click Edit in the Actions column for a backup policy.
Configure the parameter as described in "Parameters."
Click OK.
Click Delete in the Actions column for a backup policy.
In the dialog box that opens, click OK.
Select a backup policy.
The VMs Using the Backup Policy tab displays all VMs that use the backup policy.
The Backup Logs tab displays all backup logs for the backup policy.
Backup Policy Name: Specify a name for the backup policy.
External Platform: Select an external platform.
Backups to Retain: Specify the maximum number of backup files that can be retained. The minimum value for this parameter is one. When the number of backup files retained exceeds the limit, new backup files will overwrite the existing ones in chronological order.
Disk Write Rate: Specify the maximum rate for writing VM backup files to the target storage volume.
IO Rate Limit: Specify an IO rate limit in Kbps.
IOPS Limit: Specify an IOPS limit.
Backup Type: Select a backup type.
Incremental: Select this option to back up only the incremental data. The first incremental backup is full backup.
Full: Select this option to back up all data.
Take Effect Now: Select whether to back up the selected external VMs immediately after the policy is created.
Frequency: Specify a backup frequency.
Date: Specify a backup date. This parameter is not available when the backup frequency is daily.
Start Time: Specify the start time for the backup plan.
End Time: Specify the end time for the backup plan. If the end time is earlier than the start time, the end time is the time on the next day.
