Manage external VMs
You can perform the following tasks on external VMs:
Restart an external VM
  1. On the top navigation bar, click Local Resources, and then select an external platform.
  1. Click the VM List tab, click More in the Actions column for the target external VM, and then select Restart.
  1. In the dialog box that opens, click OK.
Start an external VM
  1. Click the VM List tab, click More in the Actions column for the target external VM, and then select Start.
Suspend an external VM
  1. Click the VM List tab, click More in the Actions column for the target external VM, and then select Suspend.
Shut down an external VM
  1. Click the VM List tab, click More in the Actions column for the target external VM, and then select Shut Down.
Power off an external VM
  1. Click the VM List tab, click More in the Actions column for the target external VM, and then select Power Off.
