Manage external platforms
After incorporating a VMware vCenter, UniCloud Usphere, or external CAS into CAS, you can centrally manage cloud resources of the external platform and migrate VMs on the hosts in the VMware vSphere to CAS.
Add an external platform
  1. On the top navigation bar, click Resources, and then select External Platform from the left navigation pane.
  1. On the External Platform List tab, click Add External Platform.
  1. Configure the parameters as described in "Parameters."
  1. Click OK.
View detailed information about an external platform
  1. On the External Platform List tab, click View in the Actions column for the target external platform.
Edit an external platform
  1. On the External Platform List tab, click Edit in the Actions column for the target external platform.
  1. Edit the parameters as described in "Parameters."
  1. Click OK.
Delete an external platform
  1. On the External Platform List tab, click Delete in the Actions column for the target external platform.
  1. In the dialog box that opens, click OK.
