Create an IDV image source VM based on a VHD file
Perform this task to create a VDI image source VM after a VHD file is converted into the QCOW2 format.
  1. From the navigation pane, select Images > Desktop Images.
  1. Click the Image Source VMs tab, and click Create.
  1. In the dialog box that opens, select Create VHD-Based VM for the creation type, and then click Next.
  1. Upload a VHD file. After the file is successfully uploaded, click Convert. After conversion, select the host where the image source VM resides and the storage path. Then, click Copy Files. After the copying operation, enter the basic information configuration page.
  1. Select image type IDV, configure basic information for the image source VM, and then click Next.
  1. Configure settings for the image source VM, and click Next.
  1. Verify that the image source VM configuration is correct, and click Finish.
Basic Info
VMs
