Create a VM
Perform this task to create a VM on a host or in a cluster. To use a VM, you must install an operating system for it.
A VM labels the first added disk as vda or hda depending on the disk type. The operation system can be installed only on disk vda or hda. Make sure the size of disk vda is different from that of disk vdb, or you might mix them up and fail to install the OS correctly.
  1. From the left navigation pane, select Data Center >Virtualization > Cluster name or Data Center >Virtualization > Cluster name > Host name.
  1. Click the VMs tab.
  1. Click Add VM and configure related VM parameters to create a VM.
  1. Click OK.
Basic info:
CPU parameters:
Memory parameters:
Network parameters:
Disk parameters:
Floppy disk parameters:
CD Drive parameters:
Hardware parameters:
