Configure AsiaInfo
When you use the anti-virus services provided by AsiaInfo, you can incorporate AsiaInfo DSM into CAS to manage DSM, VM anti-virus, and anti-virus policies.
Add an AsiaInfo security server
  1. On the top navigation bar, click Services.
  1. From the left navigation pane, select Security > Anti-Virus.
  1. Click the AsiaInfo Security Settings tab.
  1. Click Add.
  1. Configure the parameters as described in "Parameters."
  1. Click OK.
Edit an AsiaInfo security server
  1. Click Edit for an AsiaInfo security server.
  1. Click OK.
Upload an AsiaInfo certificate
  1. Click Upload for an AsiaInfo security server.
  1. Click the  icon, and then select an AsiaInfo certificate.
  1. Click OK.
Test connectivity to an AsiaInfo security server
  1. Click Test Connectivity for an AsiaInfo security server.
The system will display the test result.
Delete an AsiaInfo security server
  1. Click Delete for an AsiaInfo security server.
  1. In the dialog box that opens, click OK.
View security policies and allocate a security policy
  1. Click the Security Policies tab.
  1. Click Allocate for a security policy.
  1. Select VMs with VM anti-virus enabled.
Reclaim a security policy from a VM
  1. Click the VMs tab.
The system will display the VMs that are already assigned security policies.
  1. Click Cancel for a VM.
