Manage cluster storage
Cluster storage management contains the following tasks:
Manage storage volumes
Storage volume management contains the following tasks:
Create a local storage volume
  1. On the top navigation bar, click Container Engine.
  1. From the left navigation pane, select Container Clusters.
  1. Click the name of a cluster.
  1. Click the Storage tab.
  1. From the left navigation pane of the Storage tab, select PVs > Local Volume.
  1. Click Create PV.
  1. Configure volume parameters as needed, and then click OK.
Create an iSCSI storage volume
  1. From the left navigation pane of the Storage tab, select PVs > iSCSI.
  1. Click Add iSCSI Storage Volume.
  1. Configure the parameters, and then click OK.
Create a Ceph storage volume
  1. From the left navigation pane of the Storage tab, select PVs > Ceph.
  1. Click Create.
View detailed information about a volume
  1. To view data in the YAML file for a volume, click View YAML in the Actions column for that storage volume.
Manage volume labels
  1. Click Labels in the Actions column for a volume.
  1. Perform the following label management actions:
Delete a volume
  1. Click Delete in the Actions column for a volume.
  1. Click OK.
Manage PVCs
Persistent Volume Claim (PVC) management contains the following topics:
Create a PVC
  1. Select PVCs.
  1. Click Add PVC.
  1. Configure PVC parameters as needed, and then click OK.
View detailed information about a PVC
  1. Select PVC.
  1. To view data in the YAML file for a PVC, click View YAML in the Actions column for that PVC.
Manage PVC labels
  1. Select PVC.
  1. Click Labels in the Actions column for a PVC.
Delete a PVC label
  1. Select PVC.
  1. Click Delete in the Actions column for a PVC.
  1. In the dialog box that opens, click OK.
