On the top navigation bar, click Resources.
From the left navigation pane, select Host Pool Name > Cluster Name > Host Name or Host Pool Name > Host Name. Make sure the selected host has GPUs.
Click the GPUs tab.
Click Add vGPU for a GPU.
Select a vGPU type and click OK.
