You can perform the following tasks on external VMs:
Restart an external VM—Perform this task to restart a running or suspended VM.
Start an external VM—Perform this task to start a shutdown VM.
Suspend an external VM—Perform this task to suspend a running VM. The data in the flash memory of a suspended VM will not be cleared.
Shut down an external VM—Perform this task to shut down a VM. Before shutting down a VM, the system will save the data in the operating system of the VM. Whether a VM can be shut down successfully depends on the operating system of the VM. Therefore, the actual state of the VM might be different from that displayed on CAS. As a best practice, shut down a VM on its operating system instead of CAS.
Power off an external VM—Perform this task to power off a VM. Data that is not saved before the power off will be lost. As a best practice to avoid data loss, shut down instead of powering off VMs.
You can manage external VMs only after you register a CAS enterprise enhanced edition.
Shutting down, suspending, or restarting an external VM will cause service interruption. Please be cautious.
You cannot shut down a VMware VM on CAS if the VMware VM is not installed with VMware tools.
On the top navigation bar, click Resources, and then select External Platform > VMware vCenter Name > Host Cluster Name from the left navigation pane.
Click More in the Actions column for the target external VM, and then select Restart.
In the dialog box that opens, click OK.
Click More in the Actions column for the target external VM, and then select Start.
Click More in the Actions column for the target external VM, and then select Suspend.
Click More in the Actions column for the target external VM, and then select Shut Down.
Click More in the Actions column for the target external VM, and then select Power Off.
