Design resource approval workflows
As a cloud administrator, you must design resource approval workflows depending on the business requirements. When you design a resource approval workflow, you must consider the levels of approval, applicable organizations, types of resources, and user role of the approver at each approval level.
Figure-1 shows the resource approval workflow for an organization. In this workflow, common users are applicants, the organization administrator is the level-2 approver, and the cloud administrator is the level-1 approver.
Figure-1 Example of resource approval workflow design
The following information describes how the workflow system works:
