Bare metal maintenance includes restoring a bare metal node, starting to manage a bare metal node, placing a bare metal node in maintenance mode, removing a bare metal node from maintenance mode, destroying a bare metal instance, reclaiming a bare metal node, and deleting a bare metal node.
You can directly delete a bare metal node in error state.
To restore a bare metal node, start managing a bare metal node, place a bare metal node in maintenance state, remove a bare metal node from maintenance state, or reclaim a bare metal node:
On the top navigation bar, click Cloud O&M, and then select Infrastructure > Bare Metal Resource Pools from the left navigation pane.
Select a bare metal node, click Actions, and then select an action to take, for example Start Management.
In the dialog box that opens, click OK.
To destroy bare metal instances:
On the top navigation bar, click Cloud Services, and then select Compute & Storage > Bare Metal from the left navigation pane.
Select one or multiple bare metal instances, and then click Destroy.
To delete bare metal nodes:
