Disk flavors include S-flavors and M-flavors. To use an S-flavor during cloud disk creation, you must add it to an M-flavor.
To create a disk flavor:
On the top navigation bar, click Cloud O&M.
From the left navigation pane, select Resource Flavors > Resource Flavors.
Select Disk from the Service Type list.
On the S-Flavors tab, click Create.
Create CPU, memory, system disk, and storage type flavors as needed.
Click OK.
Table-1 Configuring S-flavor parameters
Parameter |
Flavor Type |
Select a flavor type:
Custom Value |
Set the flavor value. For a disk size, the flavor value can be one of the following types:
Click the M-Flavor tab.
Click Create.
Set the disk size and select a storage type.
