On the top navigation bar, click Cloud O&M.
From the left navigation pane, select Infrastructure > Storage Resource Pools.
Click Create.
Configure disk storage type parameters as needed.
Click Create.
Table-1 Configuring disk storage type parameters
Parameter |
Name |
Configure the name for the disk storage type. The name you enter will be displayed in the custom storage type list in s-flavor creation. |
AZ |
Select an AZ. The system will display the storage resource pools of the AZ. |
Type |
Select a file system type: · Shared File System—Use the shared storage resources provided by clusters on the hypervisor of the selected AZ. · Local File System—Use the local storage resources of the compute node in the selected AZ. |
Storage Pools |
Select storage pools to store storage volume files. You can create disks in specified storage pools. |
To use a storage type, you must associate with an s-flavor or m-flavor. |
