To create an image from a cloud host, you must take a snapshot of the cloud host, and then convert the snapshot to an image. A cloud administrator can convert a snapshot to a public or private image. An organization administrator can convert a snapshot only to a private image.
To create an image from a cloud host:
On the top navigation bar, click Cloud Services.
From the left navigation pane, select Compute & Storage > Cloud Hosts.
Specify a name and description, and then click OK.
From the left navigation pane, select Snapshots.
Select a snapshot, and then click Convert to Image.
Select Public or Private, and then click OK.
The snapshot will be deleted after being converted to an image.
