Resource flavors define resources that can be used by cloud hosts. You can create S-flavors, such as the number of CPU cores, storage type, memory size, and system disk size, and combine the S-flavors to create M-flavors for users to select at host creation or application.
This section contains the following topics:
Table-1 Cloud host flavor description
Cloud service |
S-flavor |
M-flavor |
Cloud host |
CPU |
Any combinations of the S-flavors |
N/A |
Memory |
System disk |
Storage type |
By default, the storage type is normal and the system randomly assigns storage pools. |
When creating an M-flavor, you can select any for an S-flavor type, which indicates all available S-flavors of the type, but you cannot select any for all S-flavor types. |
On the top navigation bar, click Cloud O&M.
From the left navigation pane, select Resource Flavors > Resource Flavors.
Select Cloud Host from the Service Type list.
On the S-Flavors tab, click Create.
Create CPU, memory, system disk, and storage type flavors as needed.
Click OK.
Click the M-Flavor tab and then click Create.
Set the flavors of CPU cores, memory, system disk, and storage type as needed.
Click Create.
You can filter S-flavors by flavor type, discrete value, minimum value, maximum value, or step value, and filter M-flavors by flavor content.
To filter cloud host flavors:
On the S-Flavor or M-Flavor tab, select a filtering criterion type, and enter the keyword in the search box.
Deleting an S-flavor also deletes M-flavors that contain the S-flavor. Deleting an M-flavor does not affect involved S-flavors.
To delete cloud host flavors:
On the S-Flavor or M-Flavor tab, perform either of the following tasks:
To delete a single flavor, click Delete for the flavor.
To delete several flavors, select the target flavors, and then click Delete above the flavor list.
