Open an SSH tool, enter the IP address in the format of ssh IP_address, and then press Enter.
Enter the username. The default username is root.
Select the password authentication method and enter the password.
Select the public key authentication method, browse to the key file, and enter the password.
On the top navigation bar, click Cloud Services.
From the left navigation pane, select Compute & Storage > Cloud Hosts.
