Key authentication is available only for Linux cloud hosts. For more information about key authentication, see "Key authentication." |
From the left navigation pane, select Compute & Storage > Key Pairs.
Click Create.
Enter the key pair name and select a creation method. If you use an existing public key, you also need to specify the public key information.
Configure key pair parameters as needed.
Click Create.
Table-1 Configuring key pair parameters
Parameter |
Name |
Enter the name of the key pair. You can specify a key pair by its name when creating a cloud host. |
Create key pair |
Create a key pair for the user. If you select this method, the system generates a new key pair after you click the Create button. Then, click Download on the Download Key Pair window to download the private key. |
Use Existing Public Key |
Use an existing key pair. If you select this method, you must select the key encryption method for an existing public key and upload the public key. |
