Create cloud host flavors
  1. On the top navigation bar, click Cloud O&M.
  1. From the left navigation pane, select Resource Flavors > Resource Flavors.
  1. Select Hosts from the Service Type list.
  1. On the Flavors tab, click Create. Set the flavor for each resource type, and then click Create.
