From the navigation pane, select ONEStor > Block Storage.
Select Volume Mappings > iSCSI Availability.
Click the button in the Status column for an iSCSI HA group to enable or disable the group.
In the dialog box that opens, click OK.
· Before editing an iSCSI HA group, disconnect all clients from the group. · To avoid client access failures, make sure all nodes in an iSCSI HA group are configured with the same routes. You can view the route information on the Block Storage > Volume Mappings > Ports page. |
Select a node pool from the Node Pool list.
Click Edit in the Actions column for an iSCSI HA group.
Edit the HA VIP, load balancer, and member node settings.
Click OK.
Before deleting an iSCSI HA group, disconnect all clients from the group. |
Select an iSCSI HA group, and then click Delete.
