Configure advanced settings
Advanced virtual switch settings include the following:
Configure port mirroring
·          The VM where the source port resides cannot be in VLAN 1.
·          You can select multiple NICs that connect to the same virtual switch as the source ports.
·          You can select a maximum of two NICs that connect to the same virtual switch as the destination ports. If you do not specify a destination port for port mirroring, mirrored packets are sent out of the uplink port of the host.
  1. From the navigation pane, select Data Center > Virtualization > Cluster name > Host name.
  1. Click the vSwitches tab.
  1. Click More for the target virtual switch, and then click Advanced.
  1. Add, edit, or delete port mirroring as needed, and then click Close.
Configuring DHCP
For a medium- or large-sized network, configuring VLAN-based DHCP services enables high-efficiency IP allocation. Each DHCP service takes effect in its specified VLAN.
·          The DHCP server of a DHCP service uses the start IP address in the IP address pool of the DHCP service.
·          The IP address pools of DHCP services cannot overlap.
·          After you delete a DHCP service from a virtual switch, VMs that have been assigned IP addresses lose the IP addresses after a period of time, and VMs newly join the virtual switch cannot obtain IP addresses.
  1. Click the DHCP Services tab.
  1. Add, edit, or delete DHCP services as needed, and then click Close.
