Manage hosts
Perform this task to connect to, edit, or delete hosts, enable or disable the maintenance mode, or manage host power options.
Enable the maintenance mode for a host
Before maintaining a host, for example, adding memory modules or disks, you can first enable the maintenance mode for the host to prevent server interruption caused by maintenance.
·          You can power off or restart a host in maintenance mode and the powered-on host will stay in maintenance mode.
·          You can configure the system to migrate running, suspended, and shutdown VMs that use shared storage to another host upon entering maintenance mode. The auto migration feature does not take effect on VMs that use local storage.
·          Enabling the maintenance mode for a host might cause some VMs to become unavailable. Make sure you are fully aware of the impacts of this operation.
To enable the maintenance mode for a host:
  1. From the navigation pane, select Data Center > Virtualization > Cluster name > Host name.
  1. Click Enter Maintenance Mode.
  1. Select whether to migrate running, suspended, or shutdown VMs, and then click OK.
Disable the maintenance mode for a host
After maintenance, you must disable the maintenance mode for the host to be used.
To disable the maintenance mode for a host:
  1. Click Exit Maintenance Mode.
  1. Click OK.
Add a host to an HA-enabled cluster
Perform this task to add a host recovered from exceptions to an HA-enabled cluster.
To add a host to a cluster:
  1. Click Add to HA-Enabled Cluster.
  1. Click OK.
Connect to a host
Perform this task to connect a host to Space Console if the host connection terminates because of network or host errors. If the host is already connected, the operation reconnects the host to Space Console.
To connect to a host:
  1. Click More, and then click Connect Host.
  1. Click OK.
Edit a host
Perform this operation to change the password used by a host to connect to Space Console. The operation also changes the root user password on the host.
  1. Click More, and then click Edit Host.
  1. Enter the current password and the new password, confirm the new password, and then click OK.
Delete a host
·          To delete a host from an HA-enabled cluster, make sure the host is no longer in use or the host is faulty and cannot be repaired. For such a deleted host to operate correctly, you must first re-install Space Console software on the host before adding the host to a cluster.
·          If the system fails to delete a host because of connection errors, reconnect the system to the host and then try again.
·          Before deleting a host, first delete all system images and desktop images from the host.
·          Deleting a host might cause some VMs to become unavailable. Make sure you are fully aware of the impacts of this operation.
  1. Click More, and then click Delete Host.
  1. Click OK.
Shut down a host
Only hosts in maintenance mode support this feature.
To shut down a host:
  1. Click More, and then click Shut Down Host.
  1. Click OK.
Bulk shut down all hosts
This operation shuts down all hosts in the system and interrupts services. Make sure you are fully aware of the impacts of this operation.
  1. From the navigation pane, select Data Center > Virtualization.
  1. Click the Hosts tab, and then click Shut Down.
  1. Select I am fully aware of the impacts of this operation, enter a password, and then click OK.
A system administrator or super administrator enters the password of its account. Any other administrator enters the password of the admin account.
Restart a host
To restart a host:
  1. Click More, and then click Reboot Host.
  1. Click OK.
Wake up a host remotely
You can wake up a shutdown host remotely. Before you wake up a host, configure wakeup parameters.
To wake up a host remotely:
  1. Click More, and then click Remote Wakeup.
  1. Click OK.
Configure wakeup parameters
  1. Click More, and then click Configure Wakeup Parameters.
  1. Configure the following parameters, and then click OK:
Deploy OVF template
Open Virtualization Format (OVF) defines the open-source VM file format specifications. An OVF template enables VMs to be compatible with different virtualization management platforms. In the current software version, the system supports OVS templates exported from virtualization platforms such as H3C CAS CVM, VMware vSphere, Oracle VM, and ZTE iECS.
  1. Click More, and then click Deploy OVF Template.
  1. Upload the OVF file. After the file is successfully uploaded, set the VM alias, CPUs, and memory, and click Next to configure the VM disks.
  1. Select the target storage file and bus type for the VM, and click Next to configure the NIC.
  1. After completing the configuration, click OK.
Basic Info
Disks
NIC
