Manage virtual switches
Edit a virtual switch
This task might cause VM network anomaly. When you perform this task, make sure you are fully aware of its impacts.
  1. From the navigation pane, select Data Center > Virtualization > Cluster name.
  1. Click the vSwitches tab.
  1. Click Edit for a virtual switch.
  1. Edit the parameters as described in "Parameters," and then click OK.
Delete a virtual switch
You cannot delete a virtual switch in use.
  1. Click Delete for a virtual switch.
  1. Click OK.
Detach a host from a virtual switch
  1. Select a virtual switch, and then click Delete for a host in the attached host list.
  1. Click OK.
