Configure advanced settings
Advanced settings for a virtual switch are as follows:
Configure port mirroring
  1. From the navigation pane, select Data Center > Virtualization > Cluster name.
  1. Click the vSwitches tab.
  1. Click Advanced for a virtual switch.
  1. Configure the port mirroring entries, and then click Close.
Configure DHCP
About DHCP
DHCP provides a framework to assign configuration information to hosts, including IP addresses, gateway addresses, and DNS server addresses.
You can specify a VLAN as the scope of a DHCP service and configure multiple DHCP services for a virtual switch. Each DHCP service applies to the VMs in the corresponding VLAN. The VLAN settings of VMs are configured by using a port profile on the virtual switch. DHCP provides efficient IP address assignment services for medium networks or large networks that contain more than 100 VMs. Configurations on VMs are simplified as VMs automatically obtain IP addresses and configurations through DHCP.
  1. Click the DHCP Services tab.
  1. Configure DHCP services, and then click Close.
