Create a VOI image source VM
The system supports creating VOI image source VMs with the default C106V, C106V Plus, C107V, C107V Plus, C107V Pro, C108V Plus, C108V Pro, C200V, C201V, C206V, C206V Plus, C207V, C207V Plus, C207V Pro, C208V Plus, and C208V Pro configurations to adapt to VOI endpoints with the corresponding models. The system also allows you to select the VOI endpoint configuration customized in Flavor configuration to adapt to non-default VOI endpoints.
  1. From the navigation pane, select Images > Desktop Images.
  1. Click the Image Source VMs tab. Click Create.
  1. On the page that opens, select image type VOI, configure the image source VM parameters, and click OK.
