Install Grid
  1. Use the Grid account to log in to the target VM.
  1. Open /u01/app/12.2.0/grid and execute the gridsetup.sh script.
  1. Select Configure Oracle Grid Infrastructure for a New Cluster, and then click Next.
Figure-1 Selecting a configuration option
  1. Select Configure an Oracle Standalone Cluster, and then click Next.
Figure-2 Cluster configuration
  1. Uncheck Configure GNS, modify the value of SCAN Name to be the same as the scan name corresponding to the scan IP in /etc/hosts, and then click Next.
Figure-3 Grid Plug and Play Information
  1. Click Add.
  1. Add database nodes according to the /etc/hosts file, and then click OK.
Figure-4 Adding cluster node information
  1. Click SSH connectivity, enter the Grid password, and then click Setup.
Figure-5 Cluster Node Information
  1. Click OK.
  1. Verify interface settings, and then click Next.
Figure-6 Verifying interface settings
  1. Select Configure ASM using block devices, and then click Next.
Figure-7 Storage option information
  1. Select No, and then click Next.
Figure-8 Grid infrastructure management repository option
  1. Configure an ASM disk group.
  1. Select External for the Redundancy parameter.
  1. Set the Allocation Unit Size to 1 MB.
  1. Click Change Discovery Path, enter /dev/oracleasm/disks, and then click OK.
  1. Select the Grid disk.
  1. Uncheck Configure Oracle ASM Filter Driver, and then click Next.
Figure-9 Creating an ASM disk group
  1. Set the same password for ASM SYS and ASMSNMP users, and then click Next.
Figure-10 Specifying ASM passwords
  1. Select Do not use Intelligent Platform Management Interface(IPMI), and then click Next.
Figure-11 Failure Isolation Support
  1. Do not select any options, and then click Next.
Figure-12 Specifying management options
  1. Use the default settings for privileged operating system groups, and then click Next.
Figure-13 Privileged operating system groups
  1. Enter the Grid installation path, and then click Next.
Figure-14 Specifying installation location
  1. Use the default inventory settings, and then click Next.
Figure-15 Creating an inventory
  1. Do not select any scripts, and then click Next.
Figure-16 Root script execution configuration
  1. Process alarms as follows:
For fixable alarms, click Fix & Check Again and follow the prompts to fix them.
To ignore all alarms, select Ignore All, click Next, and then click Yes.
Figure-17 Performing prerequisite checks
  1. View the configuration summary, and then click Install.
Figure-18 Summary
  1. Run configuration scrips as the root user on the database nodes one by one.
Figure-19 Executing configuration scripts
  1. Click OK after script execution is finished.
  1. Click OK after installation is finished.
Figure-20 Installation finished
