The following information describes the tasks to manage an IDV desktop pool.
From the navigation pane, select Desktop Pools & Groups > Desktop Pools.
Select a desktop pool, and then click Edit.
Edit the desktop pool configuration, and then click Finish.
Select a desktop pool, and then click Delete.
In the dialog box that opens, click OK.
With this feature enabled for a desktop pool, desktops in the desktop pool will automatically install the drivers on the Applications > Application Center > Drivers page and applications on the Applications > Application Center > App Store page if users open the app store on the desktops.
Select the target VDI desktop pool.
Click More at the top of the desktop pools page.
Select Auto Software Driver Installation, and then select Enable or Disable.
A desktop pool uses one authorization policy for all desktops if it performs anonymous user authorization. This policy is configurable at the pool level. To change the authorization for anonymous users, edit the desktop pool configuration.
In a desktop pool for single-user authorization, authorization policies are configurable on a per-client basis.
Select the target desktop pool, and then click
in the Authorized User Login Name column for a client.
In the dialog box that opens, change the user or authorization policy, and then click OK.
This task is applicable to IDV desktop pools that perform multi-user authorization.
Select the target desktop pool, and then click Users on top of the client list.
In the dialog box that opens, select users or user groups, and then select their respective authorization policies, and then click OK.
In the dialog box that opens, select users or user groups, and then click Delete Authorizations. In the dialog box that opens, click OK.
To help an online IDV desktop user resolve desktop issues, you can access that desktop from its console.
From the left navigation pane, select Desktop Pools & Groups > Desktop Pools.
Select the target IDV desktop pool.
Click Console in the Actions column for a desktop.
Start IDV clients:
To start multiple clients, select the target clients from the client list, click More on top of the list, and then select Start. In the dialog box that opens, click OK.
To start a client, click Start in the Actions column for that client. In the dialog box that opens, click OK.
Shut down IDV clients:
To shut down multiple clients, select the target clients from the client list, click More on top of the list, and then select Shut Down. In the dialog box that opens, click OK.
To shut down a client, click Shut Down in the Actions column for that client. In the dialog box that opens, click OK.
Restart IDV clients:
To restart multiple clients, select the target clients from the client list, click More on top of the list, and then select Restart. In the dialog box that opens, click OK.
To restart a client, click More in the Actions column for that client, and then select Restart. In the dialog box that opens, click OK.
Remove IDV clients:
To remove multiple IDV clients, select the target clients from the client list, click More on top of the list, and then select Remove All. In the dialog box that opens, select I am fully aware of the impacts of this operation, enter the administrator password, and then click OK.
To remove a client, click More in the Actions column for that client, and then select Remove. In the dialog box that opens, select I am fully aware of the impacts of this operation, enter the administrator password, and then click OK.
You can configure desktop monitoring settings on a per-client basis. To view desktop summary and performance monitoring data for a client on its details page, you must enable that client to report monitoring data.
Click More in the Actions column for a client, and then select Set Monitor Info.
In the dialog box that opens, configure desktop monitoring settings:
To view summary and performance data about the desktop, enable it to report data, set the report interval, and then click OK.
To disable the system from displaying summary and performance data about the desktop, disable it from reporting data, and then click OK.
The system displays desktop summary and performance monitoring data for an IDV client if you enable that client to report desktop monitoring data. To remove history desktop monitoring data for that client and view only new monitoring data, perform this task.
Select one or multiple clients from the client list, click More on top of the list, and then select Clear Monitor Info.
In the client list, click the name of a client.
The client details page opens. On the page, you can obtain basic information, summary data, performance data, and process data about the client.
On the page, you can perform various client operations, including startup, restart, shutdown, removal from the desktop pool, and monitoring setup.
To view summary and performance data about an IDV desktop, you must enable the IDV client to report monitoring data. |
