Create an IDV desktop pool
Perform this task to create an IDV desktop pool for deployment of desktops that are accessible to one dedicated user, multiple users, or anonymous users.
Make sure you have completed the following tasks in Space Console:
  1. From the navigation pane, select Desktop Pools & Groups > Desktop Pools.
  1. Click Create Desktop Pool or Create.
  1. Select the IDV desktop type, configure basic desktop pool information, and then click Next: Login Info.
  1. Configure settings for desktop login, and then click Next: Configuration.
  1. Configure the desktop pool, and then click Next: Confirm Configuration.
  1. Verify that the desktop pool configuration is correct, and then click Finish.
