Configure DRS
About DRS
Dynamic resource scheduling (DRS) enables the system to perform real-time monitoring on compute and storage resources of a cluster and dynamically allocate resources to VMs.
If the available resources of a host are insufficient for its VMs, the system automatically migrates the VMs to other hosts to ensure that each VM can obtain sufficient resources. After you enable DRS, you do not need to monitor the CPU usage and memory usage of the VMs in the cluster. Automatic resource allocation and load balancing also reduce the data center cost greatly.
DRS includes compute DRS and storage DRS.
Application scenarios
DRS is applicable to scenarios where service load surges occur frequently.
DRS provides the following benefits:
  1. From the navigation pane, select Data Center > Virtualization > Host pool name > Cluster name.
  1. Click DRS.
  1. Configure compute DRS and storage DRS parameters as needed, and then click OK.
