The following information describes the tasks to manage a VDI desktop pool.
If you select the Deploy Now option when you edit a desktop pool, the system deploys desktops immediately after you edit the desktop pool settings.
From the navigation pane, select Desktop Pools & Groups > Desktop Pools.
Select a desktop pool, click More at the top of the page, and then select Edit.
Edit the desktop configuration step by step, and then click Finish.
You cannot edit the desktop pool while the system is deploying desktops in the pool. |
Select a desktop pool, click More at the top of the page, and then select Delete.
In the dialog box that opens, click OK.
Select a desktop pool, click More at the top of the page, and then select Import Authorizations.
Select the authorization file, select the column in the file for each parameter, and then click Next.
Verify the imported data, and then click OK.
Select a desktop pool.
Change the authorization policy depending on the purpose:
To use the default authorization policy for the pool, do not select any policy.
Space Console reserves the configured maximum amount of CPU and memory resources for VIP desktops. To guarantee that a desktop can always obtain the maximum amount of CPU and memory resources, promote its priority level to VIP. To configure the VIP desktop policy for settings such as resource usage alarms and alarm notifications, see "Authorization Policies."
· The promoted desktop will automatically restart if it is operating when you promote it. To prevent data loss, save desktop data before you promote an operating desktop. · If the desktop is in down state when you promote it, the promotion takes effect when the desktop restarts. |
Before you can promote a desktop, make sure it is not in abnormal state.
If the target commmon desktops are operating, save desktop data to prevent data loss.
Select the target common desktops, and then click Promote to VIP.
To remove the priority that a VIP desktop has in obtaining CPU and memory resources, demote its priority level to common. Then, Space Console will not reserve CPU or memory resources for that desktop.
· The demoted desktop will automatically restart if it is operating when you demote it. To prevent data loss, save desktop data before you demote an operating desktop. · If the desktop is in down state when you demote it, the demotion takes effect when the desktop restarts. |
Before you can demote a VIP desktop, make sure it is not in abnormal state.
Select the target VIP desktops, click More on top of the desktop list, and then select Demote to Common.
To deploy software on a desktop, you can perform this task or use the software deployment feature for application management.
With software deployment, you can deploy only a limited set of software. You cannot deploy such software as personal software, input methods, large-sized software, and user-specific software.
This task enables you to update the system disks of all desktops in a desktop pool with the same desktop image. The original system disks of the desktops are deleted. This task allows you to install all desired software.
· This operation will delete all system disks of the desktops in the desktop pool. Data on the original system disks will be lost, including desktop data, user configuration, and software installed on the system disks. Please back up data in advance. If a desktop does not have data disks, all its data will be deleted. · This task disconnects the connections to desktops. Desktops and their images are not available during the rebuild. · To prevent user data loss, the desktops will log out users when they first connect to the desktops after a system disk rebuild. To use the updated desktops, the users only need to reconnect to the desktops. · Make sure the selected source desktop image contains an operating system and required tools. When you build the source image VM, use the optimization tool to set the storage location for user profiles to a disk other than the system disk. In addition, make sure the system disk does not contain user data. For more information about creating a source image VM, see "Build a VDI image source VM." · System disk rebuild is available only for static Windows and UOS VDI desktop pools that use fast initialization and are created for local users or domain users. |
Select the target static VDI desktop pool, click More at the top of the page, and then select System Disk Rebuild.
In the dialog box that opens, enter the confirm string (case insensitive), and then click OK.
To verify the rebuild status, review the operation log.
To enable or disable the anti-virus service for all desktops in a desktop pool:
Select a desktop pool, click More, select Anti-Virus, and then select On or Off.
In the dialog box that open, click OK.
To enable or disable the anti-virus service for specific desktops in a desktop pool:
On the Desktop List area, select one or multiple desktops, click More, select Anti-Virus, and then select On or Off.
Select a desktop pool, and then click Preauthorize.
Select users or user groups to be removed from the preauthorization list, and then click Delete Authorizations.
Click OK.
To remove the access right of a user to a desktop, perform this task. This task also removes the authorization policy associated with the authorized user that is removed from the desktop.
From the desktop list, select the target desktops.
Click More on top of the list, and then select Delete Authorizations. Alternatively, click the Delete icon
in the Authorized User Login Name column for the desktop.
Starting multiple desktops in bulk might cause boot storm and affect user experience. Do not start multiple desktops in bulk when the service load is heavy. |
Start desktops:
To start all desktops in the desktop pool, click More at the top of the page, and then select Start All. In the dialog box that opens, click OK.
To start multiple desktops, select the target desktops from the desktop list, and then click Start on top of the list. In the dialog box that opens, click OK.
To start a desktop in the desktop pool, click More in the Actions column for that desktop, and then select Start. In the dialog box that opens, click OK.
To help a desktop user resolve desktop issues, you can access that desktop from its console. You cannot open the desktop console of a user without permission while that user is using the desktop. You can open the console of a desktop in the following situations:
No client is connected to the desktop.
You have permission from the user that is using the desktop.
The user permits you to perform a remote assistance.
You cannot use the console to view the desktop environment setup if the user rejects remote assistance.
Click Console in the Actions column for a desktop.
Perform the following operations as needed in the console:
To disconnect from the desktop, click Disconnect. This option is available only if you are connected to the desktop.
To connect to the desktop, click Connect. This option is available only if you are disconnected from the desktop.
To refresh the desktop, click Refresh.
To start the desktop, click Enable.
To restart the desktop, click Restart.
To shut down the desktop, click Shut Down. In the dialog box that opens, click OK.
To use a keyboard shortcut on the desktop, click Send, and then select the desired shortcut key or key combination.
To mount a virtual CD-ROM, click Install Template Tool, and then select Mount CD-ROM.
To unmount the virtual CD-ROM, click Install Template Tool, and then select Unmount CD-ROM.
Shut down desktops:
To shut down all desktops in the desktop pool, click More at the top of the page, and then select Shut Down. In the dialog box that opens, click OK.
To shut down multiple desktops, select the target desktops from the desktop list, and then click Shut Down on top of the list. In the dialog box that opens, click OK.
To shut down a desktop in the desktop pool, click More in the Actions column for that desktop, and then select Shut Down. In the dialog box that opens, click OK.
Restarting multiple desktops in bulk might cause boot storm and affect user experience. Do not restart multiple desktops in bulk when the service load is heavy. |
To restart desktops:
To restart all desktops in the desktop pool, click More on the top of page, and then select Restart. In the dialog box that opens, click OK.
To restart multiple desktops, select the target desktops from the desktop list, and then click Restart on top of the list. In the dialog box that opens, click OK.
To restart a desktop in the desktop pool, click More in the Actions column for that desktop, and then select Restart. In the dialog box that opens, click OK.
Power off desktops:
To power off all desktops in the desktop pool, click More at the top of the page, and then select Power Off. In the dialog box that opens, click OK.
To power off multiple desktops, select the target desktops from the desktop list, and then click Power Off on top of the list. In the dialog box that opens, click OK.
To power off a desktop in the desktop pool, click More in the Actions column for that desktop, and then select Power Off. In the dialog box that opens, click OK.
This task is available for the static VDI desktop pools created for local or domain users. This task exports information about all desktops in the selected desktop pool to an Excel file.
Click More on top of the desktop list, and then select Export All.
Delete desktops:
To delete all desktops in the desktop pool, click More on top of the desktop list, and then select Delete All. In the dialog box that opens, click OK.
To delete multiple desktops, select the target desktops from the desktop list, click More on top of the list, and then select Delete. In the dialog box that opens, click OK.
To delete a desktop in the desktop pool, click More in the Actions column for that desktop, and then select Delete. In the dialog box that opens, click OK.
This task only removes the selected desktops from the desktop pool without deleting their VMs. To view information about the VMs, access the Data Center > Virtualization page.
Remove desktops:
To remove all desktops from the desktop pool, click More on top of the desktop list, and then select Remove All. In the dialog box that opens, click OK.
To remove a desktop from the desktop pool, click More in the Actions column for that desktop, and then select Remove. In the dialog box that opens, click OK.
You can lock a desktop for maintenance purposes. A locked desktop is not accessible to users and the administrator can perform only the authorization operation on it.
Lock desktops:
To lock multiple desktops, select the target desktops from the desktop list, click More on top of the list, and then select Lock. In the dialog box that opens, click OK.
To lock a desktop in the desktop pool, click More in the Actions column for that desktop, and then select Lock. In the dialog box that opens, click OK.
Perform this task to unlock a desktop that has been manually locked or locked because of a software exception. The desktop is available for use after it is unlocked.
Unlock desktops:
To unlock multiple desktops, select the target desktops from the desktop list, click More on top of the list, and then select Unlock. In the dialog box that opens, click OK.
To unlock a desktop in the desktop pool, click More in the Actions column for that desktop, and then select Unlock. In the dialog box that opens, click OK.
This task restores the system disk of a desktop to its initial state without any impact on data disks.
To reinstall the system of a desktop or restore a desktop that has failed because of an unrecoverable error, perform this task.
To view the system disk restoration result, see the task console in the top right corner of Space Console.
To restore the system disk of a desktop, make sure all of the following conditions are met:
The desktop is in a static VDI desktop pool.
The deskop pool is not deployed on ARM hosts.
Protection mode is disabled on the desktop.
The system disk is in Virtio format.
To avoid data loss, do not perform any operations during system disk restoration. |
Restore the system disks of desktops:
To restore the system disks of multiple desktops, select the target desktops from the desktop list, click More on top of the list, and then select Restore System Disk. In the dialog box that opens, enter the case-insensitive string CONFIRM and click OK.
To restore the system disk of a desktop in the desktop pool, click More in the Actions column for that desktop, and then select Restore System Disk. In the dialog box that opens, enter the case-insensitive string CONFIRM and click OK.
Perform this task to upgrade the CAStools driver on one or multiple desktops.
Upgrade the CAStools driver:
To upgrade the driver on multiple desktops, select the target desktops from the desktop list, click More on top of the list, and then select Upgrade Driver. In the dialog box that opens, click OK.
To upgrade the driver on a desktop in the desktop pool, click More in the Actions column for that desktop, and then select Upgrade Driver. In the dialog box that opens, click OK.
To add VMs in the data center to a desktop pool to provide desktop services, perform this task. You can add a VM to only one desktop pool.
Before you perform this task, add VMs to the system on the Data Center > Virtualization page.
The system checks VMs for an AC97 sound card, QX1 display card, and SPICE console before it adds them to a desktop pool. If a VM lacks any of these options, a desktop configuration check dialog box opens. When you receive this dialog box, click OK. The system will automatically adds the missing options to the VM, and then adds it to the pool. |
Click More on top of the desktop list, and then select Add Desktops. In the dialog box that opens, select one or multiple desktops, and then click OK.
Perform this task to collect log data from an online desktop installed with a VdiAgent.
Click More in the Actions column for an online desktop installed with a log collector agent. A message box opens, informing you that you can access the System > Logs menu to view the collected log data.
Click OK. The desktop log page opens.
Add GPU devices to desktops:
To add GPU devices to multiple desktops, select the target desktops from the desktop list, click More on top of the list, and then select Add GPU Devices. Select a GPU resource pool, configure the number of GPU devices to be added to each desktop, and then click OK.
To add a GPU device to a desktop in the desktop pool, click More in the Actions column for that desktop, and then select Add GPU Devices. Select a GPU resource pool, configure the number of GPU devices to be added to the desktop, and then click OK.
Resource Pool: Select a resource pool. If you select a GPU resource pool, the desktop accesses the physical GPU resources of the host through GPU passthrough. If you select a vGPU resource pool, the desktop accesses the vGPU resources of the host. ARM hosts do not support GPU/vGPU.
Service Template: Select a service template. The service template defines the rule that how desktops use the GPU resources on the host. The host allocates these resources to desktops based on their priorities. ARM hosts do not support service templates.
Driver Type: Select a driver type. Only VFIO is supported. ARM hosts do not support GPU/vGPU.
Exclusive Mode: Select whether the desktop can exclusively use the specified GPU/vGPU resources. If you enable this feature, the GPU/vGPU resources cannot be used by any other desktops. This feature is available only when the host has available GPU/vGPU resources that have been added to the selected GPU resource pool.
Resource Count: Set the maximum number of GPU/vGPU resources that can be used by the desktop. The value depends on the resource pool type and state of the exclusive mode feature:
If you select a vGPU resource pool, the value for this parameter is 1.
If you select a GPU resource pool and exclusive mode is disabled, the value is the maximum number of GPUs on a single host in the resource pool. For example, if the resource pool has three hosts, and the hosts have three, two, and two GPUs, respectively, the value for this parameter is 3.
If you select a GPU resource pool and exclusive mode is enabled, the value is the number of available GPUs on the host to which the desktop belongs.
Remove GPU devices from desktops:
To remove GPU devices from multiple desktops, select the target desktops from the desktop list, click More on top of the list, and then select Remove GPU Devices.
To remove GPU devices from a desktop in the desktop pool, click More in the Actions column for that desktop, and then select Remove GPU Devices.
Before you enable 4K resolution for a desktop, you must shut down that desktop.
To gain the benefits of 4K resolution, make sure the monitor of the client endpoint supports 4K resolution.
Enable 4K resolution for desktops:
To enable 4K resolution for one or multiple desktops, select the target desktops, click More on top of the desktop list, and then select Enable 4K Resolution. In the dialog box that opens, click OK.
To enable 4K resolution for a desktop in the desktop pool, click More in the Actions column for that desktop, and then select Enable 4K Resolution. In the dialog box that opens, click OK.
Before you disable 4K resolution for a desktop, shut down that desktop first so the change can take effect after the desktop restarts.
Disable 4K resolution for desktops:
To disable 4K resolution for one or multiple desktops, select the target desktops, click More on top of the desktop list, and then select Disable 4K Resolution. In the dialog box that opens, click OK.
To disable 4K resolution for a desktop in the desktop pool, click More in the Actions column for that desktop, and then select Disable 4K Resolution. In the dialog box that opens, click OK.
If a user no longer needs a desktop, you can release it for use by other users. This task is applicable to desktops in a dynamic or manual VDI desktop pool.
Release desktops:
To release all assigned desktops in the desktop pool, click More at the top of the page, and then select Release. In the dialog box that opens, click OK.
To release a desktop in the desktop pool, click More in the Actions column for that desktop, and then select Release. In the dialog box that opens, click OK.
This task is applicable only to a manual desktop pool. To make sure you can revert all desktops in a manual desktop pool to the state at a point in time, create a restore point. If you set multiple restore points, the system retains only the most recent restore point.
Click More on top of the desktop list, and then select Set Restore Point.
This task is applicable only to a manual desktop pool. It restores all desktops in a manual desktop pool to the most recent restore point.
Click More on top of the desktop list, and then select Restore Desktop Pool.
From the left navigation pane, select Desktop Pools & Groups > Desktop Pools.
Click the name of a desktop in the desktop list.
The Data Center > Virtualization page opens. On the page, you can view detailed information about the desktop.
Perform this task to view information about each peripheral of a desktop, including their device name, VID, PID, type, and state.
Click More in the Actions column for a desktop, and then select Peripherals.
A dialog box opens to display detailed peripheral information.
