After you create a VDI desktop pool, you can deploy desktops in the desktop pool and authorize users and endpoints to use the desktops deployed in the pool.
Perform this task to deploy desktops depending on the business requirements.
From the navigation pane, select Desktop Pools & Groups > Desktop Pools.
Select a desktop pool, and then click Bulk Deploy.
Configure basic deployment settings, and then click Next: Configure NIC.
Configure the network settings, and then click Next: Confirm Configuration.
Verify that the deployment configuration is correct, and then click Finish.
VMs to Deploy: Specify the number of VMs to be deployed as desktops. This setting cannot exceed the maximum number of desktops allowed in the desktop pool. As a best practice, deploy only up to three desktops if the pool uses full initialization for desktops.
Start Desktop ID: Start serial number for desktop names and computer names. Assume the desktop pool name is aa, the desktop prefix is bb, and the start desktop ID is 1. Then, for the first desktop deployed, the desktop name is aa-001 and the computer name is bb001. For the 345th desktop deployed, the desktop name is aa-345 and the computer name is bb345.
Configure: Select a resource flavor for the desktops depending on the required performance. Each flavor represents a set of CPU, memory, and system disk resources for each desktop. You can select the predefined flavor for high, medium, or low performance, or self-define the resources to be provisioned for each desktop.
OU: If the desktop pool is for domain users, specify the DN of the OU for the desktops. When you specify this option, use the ou=value,dc=value,dc=value format. For example, to specify the test OU in the example.com domain, enter the ou=test,dc=example,dc=com string.
Fast Deployment: To accelerate desktop deployment and conserve storage when you deploy desktops based on the base image file, enable this feature.
Boot After Deploy: Initialize the desktops immediately after they are deployed.
Protection Mode: To disable user data persistence and store user data as temporary data, enable protection mode. Any changes a user made to a desktop in protection mode are lost when the desktop is restarted from Space Console or shut down from the client.
4K Resolution: To enable 4K display on the desktops, enable this feature.
Activation Key: Activation key for the desktop operating system. You must specify the activation key if the desktop image of the desktop pool is Windows XP and the initialization type of the desktop pool is full initialization.
Resource Pool: To deploy GPUs for the desktops, select a GPU resource pool. A GPU resource pool can provide GPU or vGPU resources. To deploy a GPU resource pool, you must also configure a service template, select a driver type, enable or disable the exclusive mode, and set the resource count. ARM hosts do not support GPU.
Service Template: A service template defines the priority of VMs that use the service template to use physical resources and the total ratio of resources that all VMs using the service template can use. You must specify a service template for each VM. To assign a high priority to a VM in using GPU resources, select a service template with a high priority for the VM. UIS Manager allocates GPU resources according to the following rules:
Allocates GPU resources in the VM boot sequence if VMs use service templates with the same priority.
Allocates GPU resources in priority order if idle GPUs are fewer than the VMs to boot.
Reclaims GPU resources from some low-priority VMs and assigns the GPU resources to high-priority VMs when the following conditions are met:
Idle GPUs are fewer than the high-priority VMs to boot.
The VMs that use the same low-priority service template occupy more resources than the resource ratio specified in the service template.
Driver Type: Select a driver type. The current version supports only VFIO.
Exclusive Mode: Select whether the VM can exclusively use the specified GPU/vGPU resources. If you select Yes, the GPU/vGPU resources cannot be used by any other VMs. This feature is available only when the host has available GPU/vGPU resources that have been added to the selected GPU resource pool. To migrate a VM when this feature is enabled, make sure sufficient GPU/vGPU resources are available on the target host and the VM is powered off.
Resource Count: Set the maximum number of GPU/vGPU resources that can be used by the VM. The value depends on the resource pool type and state of the exclusive mode feature:
If you select a vGPU resource pool, only 1 is available.
If you select a GPU resource pool and exclusive mode is disabled, the value is the maximum number of GPUs on a single host in the resource pool. For example, if the resource pool has three hosts, and the hosts have three, two, and two GPUs, respectively, the value is 3.
If you select a GPU resource pool and exclusive mode is enabled, the value is the number of available GPUs on the host attached to the VM.
Network: Select the vSwitch and port profile for the desktops and configure their IPv4 and IPv6 network settings. IPv4 network parameters are available only if IPv6 address management is enabled for VMs in the system setup.
IP Assignment Mode:
On an IPv4 network, select DHCP for dynamic IP assignment or select static allocation. If you select DHCP, make sure the network has DHCP servers. If you select static allocation, you must manually specify network parameters for the desktops, including an IPv4 address range. The IPv4 address ranges assigned to desktop pools cannot overlap.
On an IPv6 network, select DHCP for dynamic IP assignment or select static allocation for manual assignment. Alternatively, you can select to not set IPv6 address assignment for now. If you select DHCP, make sure the network has DHCPv6 servers for IPv6 address assignment. If you select static allocation, you must manually specify network parameters for the desktops, including an IPv6 address address range. The IPv6 address ranges assigned to desktop pools cannot overlap.
If static IPv4 or IPv6 assignment is used, click View Assigned IP Ranges to view the IP address ranges that have been assigned to desktops. This list displays only IP assignment records. It is not refreshed when VMs are deleted.
To automatically assign idle desktops to users when they log in to their VDI clients, add their usernames, endpoints, or OUs to the preauthorization list.
If a VDI desktop pool is for endpoint users, authorization is performed on a per-endpoint basis. Users can access the desktops in the VDI desktop pool from preauthorized endpoints, without providing user account information.
Select a desktop pool, and then click Preauthorize.
Add users, user groups, and OUs to the preauthorization list:
To add users to the preauthorization list:
Click Select Users.
Select one or multiple users, select their respective authorization policies, and then click OK.
To add user groups to the preauthorization list:
Click Select User Groups.
Select one or multiple user groups, select their respective authorization policies, and then click OK.
To add OUs for domain users to the preauthorization list:
Click Select OU.
Select one or multiple OUs, select their respective authorization policies, and then click OK.
To change authorization policies for preauthorized objects (users, user groups, or OUs of domain users):
Select the target authorized objects, and then click Change Authorization Policy.
In the dialog box that opens, select the desired authorization policy, and then click OK.
To use the default authorization policy for the pool, do not select any policy.
To remove preauthorized objects from the preauthorization list:
Select one or multiple preauthorized objects, and then click Delete Authorizations.
In the dialog box that opens, click OK.
The users or endpoints will be unable to access any cloud desktops in the desktop pool.
Perform this task to manually authorize a user or endpoint to use a desktop.
From the left navigation pane, select Desktop Pools & Groups > Desktop Pools.
Select the target VDI desktop pool.
