- 12-Network Management and Monitoring Command Reference
- 01-GOLD commands
- 02-iFIT commands
- 03-NETCONF commands
- 04-NQA commands
- 05-NTP commands
- 06-Packet capture commands
- 07-PTP commands
- 08-SNMP commands
- 09-TCP connection trace commands
- 10-Information center commands
- 11-Network synchronization commands
- 12-System maintenance and debugging commands
- 13-Process monitoring and maintenance commands
- 14-Mirroring commands
| 02-iFIT commands | 215.85 KB |
iFIT commands for application-level quality measurement
bind interface
Use bind interface to bind an interface to an instance.
Use undo bind interface to unbind an interface from an instance.
bind interface interface-type interface-number
undo bind interface [ interface-type interface-number ]
An instance is not bound to any interface.
iFIT instance view
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this argument, the default setting will be restored. In the current software version, you can only bind a Layer 3 physical interface or Layer 3 aggregate interface to an instance.
Before enabling iFIT measurement on the ingress node of an instance, execute this command to bind an interface to the instance. After you bind an interface to an instance, iFIT parses the packets passing through the interface to identify the target packets and add an iFIT header to each target packets. Meanwhile, iFIT will count the number of target packets, and send the packet count and timestamp to the analyzer at intervals through gRPC.
You can repeat this command to bind multiple interfaces to an instance. You can configure only one set of flow match criteria for an instance. Each bound interface matches target flows based on the same set of criteria and assigns different flow IDs to the target flows. iFIT measures the delay and packet loss of the target flows on a per-interface basis.
# Bind interface GigabitEthernet1/0/6 to instance abc.
[Sysname] ifit enable
[Sysname-ifit] instance abc
[Sysname-ifit-instance-abc] bind interface gigabitethernet 1/0/6
# Bind interface Route-Aggregation 1 to instance abc.
[Sysname-ifit-instance-abc] bind interface route-aggregation 1
delete dynamic-flow
Use delete dynamic-flow to delete iFIT dynamic flows.
delete dynamic-flow { all | device-id device-id flow-id flow-id }
iFIT view
all: Specifies all dynamic flows.
device-id device-id: Specifies an iFIT device by its ID in the range of 1 to 1048575. A flow ID and a device ID uniquely identify an iFIT flow.
flow-id flow-id: Specifies an iFIT flow by its ID in the range of 1 to 1048575.
A flow ID is generated on the ingress node and passed to the transit nodes and egress node. A flow ID and a device ID/device IP uniquely identify a flow and you can execute the display ifit flow static command to view the flow ID.
# Delete the dynamic flow with device ID 2 and flow ID 4098.
[Sysname-ifit] delete dynamic-flow device-id 2 flow-id 4098
device-id
Use device-id to specify a device ID.
Use undo device-id to restore the default.
device-id device-id
undo device-id
No device ID is specified.
iFIT view
device-id: Specifies a device ID in the range of 1 to 1048575.
A device ID uniquely identifies a device on an iFIT network. To make iFIT function correctly, specify a device ID and make sure the specified device ID is unique.
# Specify 100 as the device ID.
[Sysname-ifit] device-id 100
display ifit flow dynamic
flow
Use display ifit flow dynamic to display dynamic flow information.
display ifit flow dynamic [ device-id device-id flow-id flow-id]
flow-id flow-id: Display information about a dynamic flow by its ID. The value range for the flow-id argument is 1 to 1048575.
A static flow is a service flow that matches a set of criteria configured on the ingress node. The ingress node generates a static flow after you enable iFIT measurement and execute the flow command to configure iFIT flow match criteria. The static flow is uniquely identified by a device ID and a flow ID. The device ID is configured by the device-id command and the flow ID is a number that is randomly generated on the ingress node in the range of 1 to 1048575. The device ID and flow ID are encapsulated in an iFIT header and passed to the transit nodes and egress node.
To view the device ID and flow ID of a static flow, execute the display ifit flow static command on the ingress node.
A dynamic flow is a service flow that the device dynamically learns. For the ingress node, if the device receives a packet that matches static flow settings, a dynamic flow with the same flow ID as the static flow is generated. For a transit node and the egress node, they parse the received packets and generate dynamic flows by dynamically learning from the iFIT headers of the packets.
# Display dynamic flow information.
<Sysname> display ifit flow dynamic
Device ID : 1
Flow ID : 4099
Flow type : Dynamic
Flow direction : Unidirection
Period : 10 sec
Actual aging-time : 300 sec
Aging threshold : 90%
Interface information
Name Direction
GigabitEthernet1/0/6 TransitInput
GigabitEthernet1/0/7 TransitOutput
Device ID |
iFIT device ID. |
Flow ID |
Flow ID of a dynamic flow. |
Flow type |
Flow type: · Static. · Dynamic. |
Flow direction |
Flow direction. If the field value is Unidirection, the flow is a unidirectional flow. |
Period |
Measurement period in seconds. |
Actual aging-time |
Actual time when the dynamic flow is aged out. |
Aging threshold |
Aging threshold of dynamic flows in percentage, that is, the percentage of the number of dynamic flows to the total number of dynamic flows supported on the device. |
Interface information |
Information about the interfaces that receive the dynamic flow. |
Name |
Interface name. |
Direction |
Flow direction for the interface: · Ingress—The target flow enters the transit network from this interface. · TransitInput—The target flow enters the node from this interface. · TransitOutput—The target flow leaves the node from this interface. · Egress—The target flow leaves the transit network from this interface. |
flow
Use display ifit flow static to display static flow information for the most recent 10 measurement periods.
display ifit flow static [ device-id device-id flow-id flow-id]
flow-id flow-id: Display information about a static flow by its ID. The value range for the flow-id argument is 1 to 1048575.
# Display the configuration of the static flow with flow ID 4097. (The static flow is measured based on 5-tuple granularity in public network IPv4 over SRv6.)
<Sysname> display ifit flow static device-id 1 flow-id 4097
Instance name : 1
Device ID : 1
Flow ID : 4097
Transmit network type : Tunnel
Flow information:
Flow type : Static
Source IP/mask length : 1.1.1.1/24
Destination IP/mask length : 2.2.2.2/32
Protocol : TCP
Source port : Any
Destination port : Any
DSCP : 23
VPN instance name : --
Measurement information:
Period : 10 sec
Measurement mode : e2e
Loss measurement : Enabled
Delay measurement : Enabled
Measurement configuration : Enabled
Measurement status : Active
Bound interface:
# Display the configuration of the static flow with flow ID 4098. (The static flow is measured based on the 5-tuple granularity for IPv4 service traffic on an MPLS/SR-MPLS private network.)
<Sysname> display ifit flow static device-id 1 flow-id 4098
Instance name : 2
Device ID : 1
Flow ID : 4098
Flow information:
Flow type : Static
Destination IP/mask length : 1.1.2.1/32
Protocol : TCP
Source port : Any
DSCP : 23
VPN instance name : vpn2
Period : 30 sec
Bound interface:
Instance Name |
Name of the iFIT instance. |
Device ID |
ID of the device that generates the iFIT target flow. |
Flow ID |
Flow ID of the target flow. |
Transmit network type |
This field is available only for static flows. Type of the transit network for iFIT measurement, Tunnel. |
Flow information |
Information about the target flow. |
Flow type |
Flow direction |
Source IP/maskLength |
Source IP address and mask length. |
Destination IP/maskLength |
Destination IP address and mask length. |
Source IPv6/prefix length |
Source IPv6 address and prefix length. |
Destination IPv6/prefix length |
Destination IPv6 address and prefix length. |
Protocol |
Protocol: · Protocol ID, an integer in the ranges of 0 to 5, 7 to 16, 18 to 131, and 133 to 255, indicating protocols except UDP, TCP, and SCTP. · UDP. · TCP. · SCTP. |
Source port |
Source port number. |
Destination port |
Destination port number. |
DSCP |
DSCP value of the target flow. |
VPN-instance name |
Name of the VPN instance bound to the target flow. |
Source MAC |
Source MAC address of the target flow. |
Destination MAC |
Destination MAC address of the target flow. |
EtherType |
Ethernet type of packets of the target flow, including: · 0x0800—IPv4 packet. · 0x86dd—IPv6 packet. |
VlanID |
VLAN ID of the target flow. |
Vlan-Priority |
VLAN priority of the target flow. |
VSI name |
Name of the VSI bound to the iFIT flow. |
Xconnect-group |
Name of the cross-connect group bound to the iFIT flow. |
Connection |
Cross-connect bound to the iFIT flow. |
Measurement information |
Information about iFIT measurement. |
Period |
Measurement period. |
Measurement mode |
Measurement mode: · trace—Hop-by-hop measurement. · e2e—End-to-end measurement. |
Peer locator |
Remote locator of the iFIT flow. |
Loss measurement |
Delay measurement state: · Enabled. · Disabled. |
Delay measurement |
Loss measurement state: · Enabled. · Disabled. |
Measurement configuration |
Configured measurement state: · Enabled. · Disabled. |
Measurement status |
Actual measurement state: · Active—iFIT measurement is in progress. · Inactive—iFIT measurement has not started. |
Bound interface |
Interface bound with the target flow. |
flow
display ifit global-information
Use display ifit global-information to display global iFIT flow information.
# On an SRv6 network, display global iFIT flow information.
<Sysname> display ifit global-information
Current instance count : 2
Enabled instance count : 1
Current static flow count : 1
Current dynamic flow count : 1
Current technical-standard : telecom
Current trace-measure per-hop : --
Current SRv6 TE policy created flow count : 1
Current SRv6 TE policy created inactive flow count: 0
Global next hop configuration : --
Current instance count |
Number of configured iFIT instances. |
Enabled instance count |
Number of instances enabled with iFIT. |
Current static flow count |
Number of static target flows. |
Current dynamic flow count |
Number of dynamic target flows. |
Current technical-standard |
Technical standards used by iFIT: · telecom—China Telecom technical standards. · unicom—China Unicom technical standards. |
Current trace-measure per-hop |
Enabling status of iFIT measurement when the device acts as a transit node in an SRv6 tunnel: · be—iFIT measurement is enabled in SRv6 BE tunnels · te—iFIT measurement is enabled SRv6 TE policy tunnels. · all—iFIT measurement is enabled both SRv6 BE and SRv6 TE policy tunnels. · --—The device does not support iFIT measurement in SRv6 tunnels. |
Current SRv6 TE policy created flow count |
Number of iFIT target flows for the SRv6 TE policy |
Current SRv6 TE policy created inactive flow count |
Number of inactive iFIT target flows for the SRv6 TE policy. |
Global next hop configuration |
Globally configured next hops. On an SRv6 or G-SRv6 network, this setting is not required and will not take effect even if you configured it. |
display ifit instance
Use display ifit instance to display iFIT instance information.
display ifit instance [ instance-name ]
instance-name: Specifies an iFIT instance by its name, a case-sensitive string of 1 to 31 characters.
# Display information about iFIT instance 1 (for an iFIT target flow to measure IPv4 service traffic based on the 5-tuple granularity).
<Sysname> display ifit instance 1
Instance name : 1
Device ID : 1
Flow information:
Flow type : Static
Protocol : TCP
Source port : Any
DSCP : 23
Period : 10 sec
Measurement configuration : Disabled
Measurement status : Inactive
Flow items:
Flow ID Interface
# Display information about iFIT instance 3 (for an iFIT target flow to measure IPv6 service traffic based on 5-tuple granularity).
<Sysname> display ifit instance 3
Instance name : 3
Device ID : 1
Flow information:
Flow type : Static
Source IPv6/prefix length : 1::1/68
Destination IPv6/prefix length : 2::2/128
Protocol : UDP
Source port : 8080
Destination port : 2308
DSCP : --
VPN instance name : vpn3
Period : 30 sec
Flow items:
Flow ID Interface
11 GigabitEthernet1/0/6
12 GigabitEthernet1/0/7
Instance Name |
iFIT instance name. |
Device ID |
iFIT device ID. |
Flow information |
iFIT target flow information. |
Flow type |
iFIT flow type: · Static. · Dynamic. |
Flow direction |
iFIT flow direction. |
Source IP address and mask length of the target flow. |
Destination IP address and mask length of the target flow. |
Source IPv6 address and prefix length of the target flow. |
Destination IPv6 address and prefix length of the target flow. |
Protocol |
Target flow protocol: · Protocol ID, an integer in the ranges of 0 to 5, 7 to 16, 18 to 131, and 133 to 255, indicating protocols except UDP, TCP, and SCTP. · UDP. · TCP. · SCTP. |
Source port |
Source port number of the target flow. |
Destination port |
Destination port number of the target flow. |
DSCP |
VPN-instance name |
Name of the VPN instance bound to the iFIT flow. |
Source MAC |
Destination MAC |
EtherType |
VlanID |
Vlan-Priority |
VSI name |
Xconnect-group |
Connection |
Measurement information. |
Period |
Measurement mode |
Measurement mode: · e2e—End to end measurement. · trace—Hop by hop measurement. |
Peer locator |
Destination locator of the iFIT flow. |
Loss measurement |
Whether packet loss measurement is enabled: · Enabled. · Disabled. |
Delay measurement |
Whether delay measurement is enabled: · Enabled. · Disabled. |
Whether measurement is enabled: · Enabled. · Disabled. |
Flow items |
iFIT target flow. Flow information is displayed only when the measure enable command is executed. |
Flow ID |
iFIT target flow ID. -- indicates that the flow has not been assigned with an ID. |
Interface bound to the iFIT target flow. |
display ifit statistic
Use display ifit statistic to display statistics about an iFIT dynamic flow for the most recent 10 measurement periods.
display ifit statistic device-id device-id flow-id flow-id [ verbose ]
device-ip device-ip: Specifies an iFIT device by its IP address, which can be any IPv4
flow-id flow-id: Specifies an iFIT dynamic flow by its flow ID. The value range for the flow-id argument is 1 to 1048575.
verbose: Displays detailed statistics about an iFIT dynamic flow. If you do not specify this keyword, this command displays brief statistics about an iFIT flow.
A static flow is a set of flow match criteria that are configured. A dynamic flow is actually a service flow, and the device collects statistics only for dynamic flows. It takes time for the device to learn and generate dynamic flows. Therefore, for the dynamic flows that are newly generated, the accuracy of statistics from the first two measurement periods is not reliable and trustable. As a best practice, do not use the statistics on new dynamic flows in the first two measurement periods.
A flow ID is generated on the ingress node and passed to the transit nodes and egress node. A flow ID and device ID uniquely identify a flow and you can execute the display ifit flow static command to view the flow ID.
# Display brief measurement information about the flow with device ID 1 and flow ID 123.
<Sysname> display ifit statistic device-id 1 flow-id 123
Period ID Direction PktCount Timestamp (sec, nsec) Interface
159627365 TransitIn 1500 1596273655,349433112 GE1/0/6
# Display detailed measurement information about the flow with device ID 1 and flow ID 123 when the flow is bound to a Layer 3 physical interface.
<Sysname> display ifit statistic device-id 1 flow-id 123 verbose
Period ID : 159627365
Period started at : 2020-08-01 17:20:55
Direction : TransitInput
Interface : GigabitEthernet1/0/6
PktCount : 844619
ByteCount : 108111232
Timestamp (sec, nsec): 2020-08-01 17:20:55.349433112 (1619278726, 349433112)
TTL : 0
Trust flag : Trusted
# Display detailed measurement information about the flow with device ID 1 and flow ID 123 when the flow is bound to an aggregate interface.
Interface : GigabitEthernet1/0/6(Route-Aggregation1)
PktCount : 844619
TTL : 0
Table 5 Command output
PeriodID |
Measurement period number. |
Period started at |
Start time of the measurement period. |
Direction |
Flow direction of the interface: · Ingress—The target flow enters the transit network from this interface. · TransitIn—The target flow enters the node from this interface. You can view this value only in the simplified iFIT flow statistics. · TransitInput—The target flow enters the node from this interface. You can view this value only in the detailed iFIT flow statistics. · TransitOut—The target flow leaves the node from this interface. You can view this value only in the simplified iFIT flow statistics. · TransitOutput—The target flow leaves the node from this interface. You can view this value only in the detailed iFIT flow statistics. · Egress—The target flow leaves the transit network from this interface. |
Physical interface name. If this interface is a member interface of an aggregate interface, this field displays in the format of physical interface name (name of the aggregate interface to which the physical interface belongs). |
PktCount |
Number of packets measured in the period. |
ByteCount |
Number of bytes detected in the period. |
Timestamp (sec, nsec) |
Timestamp value for the delay measurement. In the detailed information, this field is displayed in the YY-MM-DD HH:MM:SS.nanosecond format. |
TTL |
This field is not supported in the current software version. TTL value of the packet. |
Trust flag |
Whether statistics reported in this period can be trusted: · Trusted. · Untrusted—The statistics are not trustable. For the dynamic flows that are newly generated, the accuracy of statistics from the first two measurement periods is not reliable and trustable. As a best practice, do not use the statistics on new dynamic flows in the first two measurement periods. |
dynamic-flow aging-time
Use dynamic-flow aging-time to specify the aging parameters for dynamic flows.
Use undo dynamic-flow aging-time to restore the default.
dynamic-flow aging-time multi-value [ threshold-percent threshold-percent ]
The aging time for dynamic flows is 10 times the measurement period and it cannot be less than 5 minutes.
iFIT view
multi-value: Specifies a multiplier value. The aging time for dynamic flows is equal to the measurement period multiplied by the multiplier value. The value range is 2 to 100.
threshold-percent threshold-percent: Specifies an aging threshold in percentage, in the range of 0 to 100. The default value for the threshold-percent argument is 0.
The device sets an aging timer for a dynamic flow upon the generation of the dynamic flow. The aging timer is reset each time the device receives a packet of the dynamic flow. If no packets of the dynamic flow are received before the aging timer expires, the device considers the dynamic flow to be inactive.
Meanwhile, the device also counts the number of the existing dynamic flows at intervals. If the number of the existing dynamic flows exceeds the aging threshold (maximum number of dynamic flows supported × aging threshold in percentage), the device ages out inactive dynamic flows. That is, the device will remove inactive dynamic flows to prevent system resources from being occupied by inactive flows.
The aging time for dynamic flows must be equal to or greater than 5 minutes. If the configured aging time is less than 5 minutes, the actual aging time will be 5 minutes.
# Configure the aging time for dynamic flows to be 20 times the measurement period.
[Sysname-ifit] dynamic-flow aging-time 20
flow
Use flow to specify a static flow to be monitored by an iFIT instance.
Use undo flow to remove the static flow settings.
· On an L3VPN/EVPN L3VPN over SRv6/G-SRv6 network:
¡ iFIT measurement based on 5-tuple granularity:
- IPv4:
flow unidirection source-ip { src-ip-address [ src-mask-length ] | any } destination-ip { dest-ip-address [ dest-mask-length ] | any } [ protocol { { sctp | tcp | udp } [ source-port src-port-number ] [ destination-port dest-port-number ] | protocol-number } ] [ dscp dscp-value ] vpn-instance vpn-instance-name
undo flow
- IPv6:
flow unidirection source-ipv6 { src-ipv6-address [ src-prefix-length ] | any } destination-ipv6 { dest-ipv6-address [ dest-prefix-length ] | any } [ protocol { { sctp | tcp | udp } [ source-port src-port-number ] [ destination-port dest-port-number ] | protocol-number } ] [ dscp dscp-value ] vpn-instance vpn-instance-name
undo flow
· On an EVPN VPLS over SRv6/G-SRv6 network:
- IPv4:
flow unidirection source-ip { src-ip-address [ src-mask-length ] | any } destination-ip { dest-ip-address [ dest-mask-length ] | any } [ protocol { { sctp | tcp | udp } [ source-port src-port-number ] [ destination-port dest-port-number ] | protocol-number } ] [ dscp dscp-value ] vsi vsi-name
undo flow
- IPv6:
flow unidirection source-ipv6 { src-ipv6-address [ src-prefix-length ] | any } destination-ipv6 { dest-ipv6-address [ dest-prefix-length ] | any } [ protocol { { sctp | tcp | udp } [ source-port src-port-number ] [ destination-port dest-port-number ] | protocol-number } ] [ dscp dscp-value ] vsi vsi-name
undo flow
· On an EVPN VPWS over SRv6/G-SRv6 network:
- IPv4:
flow unidirection source-ip { src-ip-address [ src-mask-length ] | any } destination-ip { dest-ip-address [ dest-mask-length ] | any } [ protocol { { sctp | tcp | udp } [ source-port src-port-number ] [ destination-port dest-port-number ] | protocol-number } ] [ dscp dscp-value ] xconnect-group group-name connection connection-name
undo flow
- IPv6:
flow unidirection source-ipv6 { src-ipv6-address [ src-prefix-length ] | any } destination-ipv6 { dest-ipv6-address [ dest-prefix-length ] | any } [ protocol { { sctp | tcp | udp } [ source-port src-port-number ] [ destination-port dest-port-number ] | protocol-number } ] [ dscp dscp-value ] xconnect-group group-name connection connection-name
undo flow
No static flow is configured for an iFIT instance.
iFIT instance view
unidirection: Specifies the unidirectional flows.
source-ip src-ip-address: Specifies a source IPv4 address of the flow, in dotted decimal format.
src-mask-length: Specifies a mask length for the source IPv4 address. The value range is 1 to 32. If you do not specify this argument, the exact match of the source IPv4 address is used.
destination-ip dest-ip-address: Specifies a destination IPv4 address of the flow, in dotted decimal format.
dest-mask-length: Specifies a mask length for the destination IPv4 address. The value range is 1 to 32. If you do not specify this argument, the exact match of the source IPv4 address is used.
source-ipv6 src-ipv6-address: Specifies a source IPv6 address of the flow.
src-prefix-length: Specifies a prefix length for the source IPv6 address. The value range is 1 to 128. If you do not specify this argument, the exact match of the source IPv6 address is used.
destination-ipv6 dest-ipv6-address: Specifies a destination IPv6 address of the flow.
dest-prefix-length: Specifies a prefix length for the destination IPv6 address. The value range is 1 to 128. If you do not specify this argument, the exact match of the destination IPv6 address is used.
protocol: Specifies a protocol type of the flow. If you do not specify this keyword, the flow can use any protocol.
· { sctp | tcp | udp }: Specifies the SCTP, TCP, or UDP protocol.
· destination-port dest-port-number: Specifies a destination port number. The value range is 0 to 65535. If you do not specify this option, the flow can use any port number as the destination port number.
· source-port src-port-number: Specifies a source port number. The value range is 0 to 65535. If you do not specify this option, the flow can use any port number as the source port number.
· protocol-number: Specifies the number of the protocol type. The value range is 0 to 255, excluding 132 (SCTP protocol number), 6 (TCP protocol number), and 17 (UDP protocol number).
dscp dscp-value: Specifies a DSCP value of the flow, in the range of 0 to 63.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To specify a flow on the public network, do not specify this option.
vsi vsi-name: Specifies the VSI to which the static flow belongs. The VSI name is a case-sensitive string of 1 to 31 characters. For more information about VSIs, see EVPN VPLS over SRv6 configuration in Segment Routing Configuration Guide.
xconnect-group group-name: Specifies the cross-connect group to which the static flow belongs. The group name is a case-sensitive string of 1 to 31 characters that cannot contain hyphens (-). For more information about cross-connect groups, see EVPN VPWS over SRv6 configuration in Segment Routing Configuration Guide.
connection connection-name: Specifies the cross-connect to which the static flow belongs. The cross-connect name is a case-sensitive string of 1 to 20 characters that cannot contain hyphens (-). For more information about cross-connects, see EVPN VPWS over SRv6 configuration in Segment Routing Configuration Guide.
source-ip any: Specifies any source IPv4 address.
destination-ip any: Specifies any destination IPv4 address.
source-ipv6 any: Specifies any source IPv6 address.
destination-ipv6 any: Specifies any destination IPv6 address.
nexthop ip-address: This option has been replaced by other configuration methods. For compatibility with history versions, you can specify this optionafter you specify source-ip any, destination-ip any, and a VPN instance, but it does not take effect.
nexthop-ipv6 ip-address: This option has been replaced by other configuration methods. For compatibility with history versions, you can specify this option after you specify source-ipv6 any, destination-ipv6 any, and a VPN instance, but it does not take effect.
Static flows are key elements for iFIT measurement. Before starting an iFIT measurement, you must execute this command to specify a flow to be measured on the ingress node. You do not need to specify a flow on the transit nodes and egress node, because the device can automatically learn the target flow through the iFIT header of the packets.
The device can perform iFIT measurement based on the following granularities in different scenarios:
· 5-tuple granularity—Used for measuring communication quality of the specified service flow. You can use 5-tuple to match service flows or perform iFIT measurement on any service traffic on a network. This granularity is available for all networks supported by iFIT.
An iFIT instance can be configured with only one static flow. If you execute this command multiple times for the same iFIT instance, the most recent configuration takes effect.
For the flows to be monitored by different instances, the flow attributes must not be identical.
The source and destination IP addresses must be legal unicast IP addresses.
# On an EVPN VPLS over SRv6/G-SRv6 network, configure instance 1 to perform iFIT measurement on a service flow with MAC address 1-1-1 and EthType field value 0x0800.
[Sysname-ifit] instance 1
[Sysname-ifit-instance-1] flow unidirection source-mac 1-1-1 eth-type 0800 vsi 1
# On an EVPN VPLS over SRv6/G-SRv6 network, configure instance 1 to perform iFIT measurement on a service flow with VLAN ID 1 and VLAN priority 7.
[Sysname-ifit-instance-1] flow unidirection vlan 1 priority-8021p 7 vsi 1
# On an EVPN VPLS over SRv6 or G-SRv6 network, configure instance abc to monitor IPv4 service flows based on 5-tuple granularity of unidirectional flow, any source IP, any destination IP, and VSI 1.
[Sysname-ifit-instance-abc] flow unidirection source-ip any destination-ip any vsi 1
# On an EVPN VPLS over SRv6 or G-SRv6 network, configure instance abc to monitor IPv4 service flows based on 5-tuple granularity of unidirectional flow, source IP 1.1.1.1/24, destination IP 2.2.2.2/24, and VSI 1.
[Sysname-ifit-instance-abc] flow unidirection source-ip 1.1.1.1 24 destination-ip 2.2.2.2 24 vpn-instance vpn1
# On an EVPN VPWS over SRv6 or G-SRv6 network, configure instance abc to monitor IPv4 service flows based on 5-tuple granularity of unidirectional flow, source IP 1.1.1.1/24, destination IP 2.2.2.2/24, cross-connect group 1, and cross-connect 2.
[Sysname-ifit-instance-abc] flow unidirection source-ip 1.1.1.1 24 destination-ip 2.2.2.2 24 xconnect-group 1 connection 2
encapsulation
ifit enable
Use ifit enable to enable the iFIT functionality globally and enter its view, or enter the existing iFIT view.
Use undo ifit enable to disable the iFIT functionality globally.
ifit enable
undo ifit enable
The iFIT functionality is disabled.
To measure the packet loss and packet delay of the network in real time, you can enable iFIT measurement.
To start iFIT measurement, perform the following tasks:
· On the ingress node, enable the iFIT functionality, configure iFIT device ID, create an instance, and configure a flow to be monitored by the instance. The configured flow is a static flow. The ingress node automatically uses the device ID to generates a flow ID, and encapsulates the flow ID and local iFIT device ID in the iFIT header of packets transmitted to the transit nodes and egress node. The flow ID uniquely identifies a flow.
· On the transit nodes and egress node, enable the iFIT functionality. If the received packet carries an iFIT header, a transit node or the egress node will perform iFIT measurement according to the flow ID, measurement period number, timestamp in the iFIT header.
# Enable iFIT and enter its view.
[Sysname-ifit]
instance
Use instance to create an iFIT instance and enter its view, or enter the view of an existing iFIT instance.
Use undo instance to delete an iFIT instance.
instance instance-name
undo instance instance-name
No iFIT instance exists.
iFIT view
instance-name: Specifies an iFIT instance by its name. The instance name is a case-sensitive string of 1 to 31 characters.
You must configure an iFIT instance on the ingress node. You can configure only one set of flow match criteria for an instance. An instance can be bound to multiple interfaces. Each bound interface matches target flows based on the same set of criteria and assigns different flow IDs to the target flows. iFIT measures the delay and packet loss of the target flows on a per-interface basis.
To perform iFIT measurement on the transit nodes and egress node, enable iFIT. After you enable iFIT on a transit node or the egress node, the point automatically identifies the flows according to the iFIT header, and perform iFIT measurement on the target flows. The flows identified automatically are dynamic flows.
# Create iFIT instance abc and enter its view.
[Sysname-ifit-abc]
measure enable
Use measure enable to enable iFIT measurement for an iFIT instance.
Use undo measure enable to disable iFIT measurement for an iFIT instance.
measure enable
undo measure enable
iFIT measurement for an iFIT instance is disabled.
iFIT instance view
You can execute this command to start iFIT measurement for an iFIT instance to monitor the packet delay and packet loss of the flow.
Before starting iFIT measurement, configure a device ID, create an iFIT instance, and configure a flow.
To modify the configuration for the device-id command or an iFIT enabled instance, disable iFIT measurement for the instance firstly.
# Enable iFIT measurement for iFIT instance abc.
[Sysname-ifit-instance-abc] measure enable
measure mode
Use measure mode to specify an iFIT measurement mode.
Use undo measure mode to restore the default.
measure mode { e2e | trace }
undo measure mode
End-to-end measurement is used.
iFIT instance view
e2e: Specifies end-to-end measurement. In this mode, only the ingress node and egress node report the measurement data.
trace: Specifies hop-by-hop measurement. In this mode, all points that are enabled with iFIT and receive the flow packets will report the measurement data.
iFIT measurement helps you to measure the network performance, troubleshoot the network faults, and measure the service quality.
To measure the packet loss and packet delay of the whole network, you can use end-to-end measurement. To accurately locate the packet loss and packet delay of each network node, you can use the hop-by-hop measurement.
# Specify hop-by-hop measurement as the measurement mode.
[Sysname-ifit-instance-abc] measure mode trace
period
Use period to specify the measurement period for an iFIT instance.
Use undo period to restore the default.
period period
undo period
The measurement period for an iFIT instance is 30 seconds.
iFIT instance view
period: Specifies the measurement period in seconds. Valid values include 1, 10, 30, 60, and 300.
iFIT collects performance statistics based on the measurement period.
· The sender records the sending time of the first iFIT packet in each sending interval, and counts the number of the iFIT packets sent from an interface in each sending interval. Sending interval = iFIT measurement period.
· The receiver records the receiving time of the first iFIT packet in each receiving interval, and counts the number of the iFIT packets received by an interface in each receiving interval. To reduce the impact of network delay and disorder on statistics, the receiving interval equals to (1+1/3) measurement period.
If network delay between the ingress and egress nodes is greater than 1/3 measurement period, the accuracy of iFIT packet loss statistics might be affected. This is because iFIT considers packets received beyond the receiving interval as packet loss. For example, if the measurement period is 1 second and the network delay greater than 1/3 seconds (333 milliseconds), the accuracy of iFIT packet loss statistics might be affected. In this case, set the measurement period to a greater value.
# Specify 60 seconds as the measurement period for an iFIT instance.
[Sysname-ifit-instance-abc] period 60
reset ifit statistic
Use reset ifit statistic to clear iFIT statistics of dynamic flows for the most recent 10 measurement periods.
reset ifit statistic [ device-id device-id flow-id flow-id | instance instance-name ]
device-id device-id: Specifies an iFIT device by its ID in the range of 1 to 1048575. In a Tunnel transit network (such as an MPLS or SRv6 private network), a flow ID and a device ID uniquely identify an iFIT flow.
flow-id flow-id: Clears statistics about an iFIT flow by its flow ID. The value range for the flow-id argument is 1 to 1048575.
instance instance-name: Clears statistics about an iFIT flow by its instance name. The instance name is a case-sensitive string of 1 to 31 characters. Only the ingress node supports instances. The transit nodes and egress node do not support instances.
# Clear iFIT statistics generated in the most recent 10 measurement periods for the flow with device ID 1 and flow ID 40962.
<Sysname> reset ifit statistic device-id 1 flow-id 40962
technical-standard
Use technical-standard to specify the standards used by iFIT.
Use undo technical-standard to restore the default.
technical-standard { telecom | unicom }
iFIT uses China Telecom standards.
iFIT view
telecom: Specifies the China Telecom standards.
unicom: Specifies the China Unicom standards.
Application scenarios
The implementation of iFIT adheres to the technical standards of China Telecom and China Unicom, which have some slight differences, for example, in encapsulation requirements for iFIT headers in IPv6 packets. Choose one set of standards as needed.
Devices included in iFIT measurement on the same SRv6 link must be configured with the same technical standards. If you fail to do so, iFIT packet parsing might fail, leading to inaccurate iFIT measurement results.
# Configure iFIT to use China Telecom standards.
[Sysname-ifit] technical-standard telecom
Use trace-measure per-hop to enable iFIT measurement on a transit node in an SRv6 tunnel.
Use undo trace-measure per-hop to disable iFIT measurement on a transit node in an SRv6 tunnel.
trace-measure per-hop [ be | te ]
iFIT measurement is disabled on a transit node in an SRv6 tunnels .
iFIT view
be: Enables iFIT measurement on a transit node in an SRv6 BE tunnel. If you do not specify the be or te keyword, this command applies to both SRv6 BE tunnels and SRv6 TE policy tunnels.
te: Enables iFIT measurement on a transit node in an SRv6 TE policy tunnel. If you do not specify the be or te keyword, this command applies to both SRv6 BE tunnels and SRv6 TE policy tunnels.
When a device acts as a transit node in an SRv6 link, you can execute this command on the device to enable iFIT measurement.
Operating mechanism
An SR node is a node that supports the SRv6 feature. The following SR nodes are available:
· Source node—Responsible for inserting an SRH into the IPv6 header of IPv6 packets, or encapsulating an outer IPv6 header into IPv6 packets and inserting an SRH into the outer IPv6 header.
· Transit node—Forwards IPv6 packets along the SRv6 path. A transit node does not participate in SRv6 processing. It can be an SRv6-aware or SRv6-unaware node.
· Endpoint node—Performs an SRv6 function for received SRv6 packets. The IPv6 destination address of the received SRv6 packets must be an SRv6 SID configured on the endpoint node. The endpoint node processes the packets based on the SRv6 SID and updates the SRH.
By configuring iFIT hop-by-hop measurement at the source node and enabling iFIT measurements at the endpoint node, to implement iFIT measurement in hop-by-hop mode on the SRv6 network, enable iFIT measurement in hop-by-hop mode on the source node and enable iFIT measurement on the endpoint node. By default, iFIT measurement is not performed on transit nodes. iFIT measurement on transit nodes is enabled by using this command, the transit nodes will parse iFIT headers for iFIT measurement.
· If you execute this command multiple times, the most recent configuration takes effect.
· On an SRv6 TE policy network, the subsequent transit nodes might not have the SRH due to special settings such as PSP. In this case, for the subsequent transit nodes to forcedly parse iFIT headers for iFIT measurement, execute trace-measure per-hop be on these transit nodes instead of trace-measure per-hop te.
# Enable iFIT measurement on transit nodes in SRv6 BE tunnels.
[Sysname-ifit] trace-measure per-hop be
