05-IP Multicast Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6826 & S9826 Switch Series Command References-Release 6715-6W10005-IP Multicast Command Reference
04-Multicast routing and forwarding commands
04-Multicast routing and forwarding commands 305.07 KB
acl (IPv4 multicast flow policy view)
Use acl to configure the multicast group range in which an IPv4 multicast flow policy takes effect.
Use undo acl to restore the default.
acl { ipv4-acl-number | name ipv4-acl-name }
undo acl
An IPv4 multicast flow policy does not take effect on any multicast groups.
ipv4-acl-number: Specifies an IPv4 basic or advanced ACL by its number, in the range of 2000 to 3999. If the ACL does not exist or does not have contain rules, the IPv4 multicast flow policy does not take effect on any multicast groups.
name ipv4-acl-name: Specifies an IPv4 basic or advanced ACL by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters and must begin with an English letter. To avoid confusion, make sure the argument is not all. If the ACL does not exist or does not have contain rules, the IPv4 multicast flow policy does not take effect on any multicast groups.
This command is not supported by the default IPv4 multicast flow policy.
If a multicast group matches the ACL specified in an IPv4 multicast flow policy, the estimated bandwidth configured in the policy is used for the multicast flows of the multicast group.
In a basic ACL rule, the source parameter specifies a multicast group range. Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
In an advanced ACL rule, the source parameter specifies a multicast source range, and the destination parameter specifies a multicast group range. Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
Example
# Configure an IPv4 multicast flow policy to take effect on the multicast group range 224.1.0.0/16.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 224.1.0.0 0.0.255.255
[Sysname] multicast routing
[Sysname-mrib] flow-policy name abc
[Sysname-mrib-flow-policy-abc] acl 2000
flow-policy (IPv4 MRIB view)
bandwidth (IPv4 multicast flow policy view)
Use bandwidth to set the estimated bandwidth for multicast flows.
bandwidth bandwidth { gbps | kbps | mbps }
undo bandwidth
The estimated bandwidth for multicast flows is 0.
bandwidth: Specifies the estimated bandwidth in the range of 1 to 10000.
gbps: Specifies Gbps as the bandwidth unit.
kbps: Specifies kbps as the bandwidth unit.
Mbps: Specifies Mbps as the bandwidth unit.
The estimated bandwidth is selected for IPv4 multicast flows as follows:
1.     If the multicast group of an IPv4 multicast flow matches the ACL specified in a custom IPv4 multicast flow policy, the estimated bandwidth configured in the policy is selected for the multicast flow.
2.     If the multicast group of an IPv4 multicast flow does not match an ACL in any custom IPv4 multicast flow policy, the estimated bandwidth configured in the default policy is selected for the multicast flow.
3.     If the default policy is not created or the estimated bandwidth is not configured in the default policy, the estimated bandwidth for the multicast flow is 0.
Example
# Set the estimated bandwidth to 200 Mbps for IPv4 multicast flow policy abc.
[Sysname-mrib-flow-policy-abc] bandwidth 200 mbps
delete ip rpf-route-static
Use delete ip rpf-route-static to delete all static multicast routes.
This command deletes all static multicast routes. To delete a specified static multicast route, use the undo ip rpf-route-static command.
# Delete all static multicast routes.
[Sysname] delete ip rpf-route-static
This will erase all multicast static routes and their configurations, you must reconfigure all static routes.
Are you sure?[Y/N]:y
ip rpf-route-static
display mrib interface
Use display mrib interface to display information about interfaces maintained by the MRIB.
display mrib interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about all interfaces maintained by the MRIB.
# Display information about interfaces maintained by the MRIB.
<Sysname> display mrib interface
 Interface: Vlan-interface1
     Index: 0x00004444
     Current state: up
     MTU: 1500
     Type: BROADCAST
     Protocol: PIM-DM
     PIM protocol state: Enabled
     Address list:
          1. Local address : 8.12.0.2/16
             Remote address: 0.0.0.0
             Reference     : 1
             State         : NORMAL
             Flags         : 0x2
Interface name.
Index
Index number of the interface.
Current state
Current status of the interface: up or down.
MTU
MTU value.
Interface type:
·     BROADCAST—Broadcast link interface.
·     LOOP—Loopback interface.
·     REGISTER—Register interface.
This field is empty if the interface is Null 0.
Protocol
Protocol running on the interface: PIM-DM, PIM-SM, IGMP, PROXY, or MD.
PIM protocol state
Whether PIM is enabled: Enabled or Disabled.
Address list
Interface address list.
Local address
Local IP address.
Remote address
Remote end IP address. This field is displayed only when the interface is vlink type.
Reference
Number of times that the address has been referenced.
Status of the interface address: NORMAL or DEL.
Flags
Interface attribute. This field displays one flag or the sum of multiple flags. For example, value 0x2 means that the interface has only one flag 0x2, and value 0x3 means that the interface has flags 0x1 and 0x2.
The following flags are available for an interface:
·     0x0—The interface is in normal status.
·     0x1—The interface address is being deleted.
·     0x2—The interface address is an IPv4 primary address.
display multicast boundary
Use display multicast boundary to display multicast boundary information.
display multicast boundary [ group-address [ mask-length | mask ] ] [ interface interface-type interface-number ]
group-address: Specifies a multicast group by its IP address in the range of 224.0.0.0 to 239.255.255.255. If you do not specify a multicast group, this command displays multicast boundary information for all multicast groups.
mask-length: Specifies an address mask length in the range of 4 to 32. The default is 32.
mask: Specifies an address mask. The default is 255.255.255.255.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays multicast boundary information for all interfaces.
# Display information about all multicast boundaries.
<Sysname> display multicast boundary
 Boundary            Interface
 224.1.1.0/24        Vlan1
 239.2.2.0/24        Vlan2
Boundary
Multicast group associated with the multicast boundary.
Boundary interface associated with the multicast boundary.
multicast boundary
display multicast fast-forwarding cache
Use display multicast fast-forwarding cache to display multicast fast forwarding entries.
display multicast fast-forwarding cache [ source-address | group-address ] * [ slot slot-number ]
source-address: Specifies a multicast source address.
group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
# Display multicast fast forwarding entries.
<Sysname> display multicast fast-forwarding cache
Total 1 entries, 1 matched
 (60.1.1.200, 225.0.0.2)
    Status     : Enabled
    Source port: 2001                   Destination port: 2002
    Protocol   : 2                      Flag            : 0x2
    Incoming interface: Vlan-interface1
    List of 1 outgoing interfaces:
        Vlan-interface2
          Status: Enabled               Flag: 0x14
Total number of (S, G) entries in the multicast fast forwarding table, and the total number of matching (S, G) entries.
(S, G) entry.
Protocol
Protocol number.
Flag
Flag of the (S, G) entry or the outgoing interface in the entry.
This field displays one flag or the sum of multiple flags. For example, value 0x2 means that the entry has only one flag 0x2, and value 0x14 means that the interface has flags 0x4 and 0x10.
The following flags are available for an entry:
·     0x1—The entry is created because of packets passed through between cards.
·     0x2—The entry is added by multicast forwarding.
The following flags are available for an outgoing interface:
·     0x1—The interface is added to the entry because of packets passed through between cards.
·     0x2—The interface is added to an existing entry.
·     0x4—The MAC address of the interface is needed for fast forwarding.
·     0x8—The interface is an outgoing interface associated with the incoming VLAN.
·     0x10—The interface is associated with the entry.
·     0x20—The interface is to be deleted.
Status
Status of the (S, G) entry or the outgoing interface:
·     Enabled—Available.
·     Disabled—Unavailable.
Incoming interface
Incoming interface of the (S, G) entry.
Outgoing interface list of the (S, G) entry.
reset multicast fast-forwarding cache all
display multicast flow-policy info
Use display multicast flow-policy info to display link selection information for IPv4 multicast flow policies.
display multicast flow-policy info [ interface interface-type interface-number | source source-address | group group-address | policy { default | name policy-name } ] *
interface interface-type interface-number: Displays link selection information for IPv4 multicast flow policies on an interface.
source source-address: Displays link selection information for IPv4 multicast flow policies for a multicast source.
group group-address: Displays link selection information for IPv4 multicast flow policies for a multicast group. The value range for the group-address argument is 224.0.0.0 to 239.255.255.255.
policy default: Specifies the default IPv4 multicast flow policy.
policy name policy-name: Specifies a custom IPv4 multicast flow policy by its name, a case-insensitive string of 1 to 63 characters.
If you do not specify the source, group, or policy parameter, this command displays link selection information for all IPv4 multicast flow policies.
# Display link selection information for all IPv4 multicast flow policies on the public network.
<Sysname> display multicast flow-policy info
Total 2 interfaces, 2 matched
  Vlan-interface100:
    Available bandwidth: 100M
    Used bandwidth: 30M (30%)
    Total 4 entries, 4 matched
    Flow bandwidth: 5M
      Total 2 entries, 2 matched
        (1.1.1.1, 225.0.0.1)
          Flow policy: video1
        (1.1.1.1, 225.0.0.2)
          Default flow policy
    Flow bandwidth: 10M
       (1.1.1.1, 225.0.0.11)
         Flow policy: audio1
       (1.1.1.1, 225.0.0.12)
         Flow policy: video2
  Vlan-interface200:
    Used bandwidth: 10M (10%)
    Flow bandwidth: 10M
      (1.1.1.1, 226.0.0.1)
        Flow policy: video3
Total number of interfaces enabled with PIM and number of matching interfaces.
Available bandwidth
Total available multicast bandwidth on the interface.
Used bandwidth
Used multicast bandwidth in percentage on the interface.
Total number of (S, G) entries that have selected the interface as an upstream interface and number of matching  (S, G) entries.
Flow bandwidth
Estimated bandwidth configured in an IPv4 multicast flow policy.
Total number of (S, G) entries for the IPv4 multicast flow policy and number of matching (S, G) entries.
(S, G) entry for the IPv4 multicast flow.
Flow policy
Name of the custom IPv4 multicast flow policy.
Default flow policy
Name of the default IPv4 multicast flow policy.
flow-ucmp unicast reserved-bandwidth
display multicast forwarding df-info
Use display multicast forwarding df-info to display DF information.
display multicast forwarding df-info [ rp-address ] [ verbose ] [ slot slot-number ]
rp-address: Specifies a BIDIR-PIM RP by its IP address.
verbose: Specifies detailed information. If you do not specify this keyword, the command displays brief information about DFs.
In a BIDIR-PIM domain, only the DF on each subnet can forward multicast data destined for a multicast group toward the RP of the group. For more information about the DF, see IP Multicast Configuration Guide.
# Display brief information about DFs.
<Sysname> display multicast forwarding df-info
Total 1 RPs, 1 matched
00001. RP address: 7.11.0.2
     Flags: 0x0
     Uptime: 04:14:40
     RPF interface: Vlan-interface1
     List of 1 DF interfaces:
       1: Vlan-interface2
# Display detailed information about DFs.
<Sysname> display multicast forwarding df-info verbose
     MID: 2, Flags: 0x0
     Uptime: 03:37:22
       Product information: 0x7a2f762f, 0x718fee9f, 0x4b82f137, 0x71c32184
       Product information: 0xa567d6fc, 0xadeb03e3
       1: Vlan-interface2
          Product information: 0xa986152b, 0xb74a9a2f
Table 5 Command output
Total number of RPs, and the total number of matching RPs.
00001
Sequence number of the entry to which the RP is designated.
RP address
IP address of the RP.
MID
ID of the entry to which the RP is designated. Each entry to which the RP is designated has a unique MID.
Flags
Entry flag.
This field displays one flag or the sum of multiple flags. For example, value 0x0 means that the entry has only one flag 0x0.
·     0x0—The entry is in correct state.
·     0x4—The entry fails to update.
·     0x8—DF interface information fails to update for the entry.
·     0x40—The entry is to be deleted.
·     0x100—The entry is being deleted.
·     0x200—The entry is in GR state.
Uptime
Length of time for which the entry has been up.
RPF interface
RPF interface to the RP.
DF interface list.
display multicast forwarding event
Use display multicast forwarding event to display statistics of multicast forwarding events.
display multicast forwarding event [ slot slot-number]
# Display statistics of multicast forwarding events.
<Sysname> display multicast forwarding event
Total active events sent: 0
Total inactive events sent: 0
Total NoCache events sent: 2
Total NoCache events dropped: 0
Total WrongIF events sent: 0
Total WrongIF events dropped: 0
Total SPT switch events sent: 0
NoCache rate limit: 1024 packets/s
WrongIF rate limit: 1 packets/10s
Total timer of register suppress timeout: 0
Table 6 Command output
Number of times that entry-active events have been sent.
Number of times that entry-inactive events have been sent.
Number of times that NoCache events have been sent.
Number of times that NoCache events have been dropped.
Number of times that WrongIF events have been sent.
Total WrongIF event dropped
Number of times that WrongIF events have been dropped.
Number of times that SPT-switch events have been sent.
NoCache rate limit
Rate limit for sending NoCache events, in pps.
WrongIF rate limit
Rate limit for sending WrongIF events, in packets per 10 seconds.
Number of times that the registration suppression has timed out in total.
reset multicast forwarding event
display multicast forwarding-table
Use display multicast forwarding-table to display multicast forwarding entries.
display multicast forwarding-table [ source-address [ mask { mask-length | mask } ] | group-address [ mask { mask-length | mask } ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number | slot slot-number | statistics ] *
group-address: Specifies a multicast group address in the range of 224.0.0.0 to 239.255.255.255.
mask-length: Specifies an address mask length. The default value is 32. For a multicast group address, the value range for this argument is 4 to 32. For a multicast source address, the value range for this argument is 0 to 32.
mask: Specifies an address mask. The default value is 255.255.255.255.
incoming-interface: Specifies the multicast forwarding entries that contain the specified incoming interface.
interface-type interface-number: Specifies an incoming interface by its type and number.
outgoing-interface: Specifies the multicast forwarding entries that contain the specified outgoing interface.
exclude: Specifies the multicast forwarding entries that do not contain the specified interface in the outgoing interface list.
include: Specifies the multicast forwarding entries that contain the specified interface in the outgoing interface list.
match: Specifies the forwarding entries that contain only the specified interface in the outgoing interface list.
statistics: Displays statistics for the multicast forwarding table.
# Display multicast forwarding entries.
<Sysname> display multicast forwarding-table
00001. (172.168.0.2, 227.0.0.1)
     Flags: 0x0
     Incoming interface: Vlan-interface10
          Incoming sub-VLAN: VLAN 11
          Outgoing sub-VLAN: VLAN 12
                             VLAN 13
     Backup incoming interface: Vlan-interface11
       1: Vlan-interface20
          Sub-VLAN: VLAN 21
                    VLAN 22
     Matched 19648 packets(20512512 bytes), Wrong If 0 packet
Table 7 Command output
Total number of (S, G) entries, and the total number of matching (S, G) entries.
00001
Sequence number of the (S, G) entry.
(172.168.0.2,227.0.0.1)
(S, G) entry.
Flags
Entry flag.
The following entries are available for an entry:
·     0x1—The entry is in inactive state.
·     0x2—The entry is null.
·     0x8—Outgoing interface information fails to update for the entry.
·     0x10—Data-group information fails to update for the entry.
·     0x20—A register outgoing interface is available.
·     0x80—The entry is in registration suppression state.
·     0x800—The entry has the associated ARP entry for the multicast source address.
·     0x400000—The entry is created by the IGMP proxy.
·     0x2000000—The entry is a BIDIR-PIM forwarding entry.
Uptime
Length of time for which the (S, G) entry has been up.
Timeout in
Length of time in which the (S, G) entry will expire.
Incoming interface
Backup incoming interface of the (S, G) entry. If the primary incoming interface of the (S, G) entry fails, multicast data arrived at the backup incoming interface will be forwarded to receivers.
Number of packets (bytes) that match the (S, G) entry, and number of packets with incoming interface errors.
The numbers are displayed as 0 if an outgoing interface of the (S, G) entry is on the specified slot.
Number of packets (bytes) that have been forwarded.
reset multicast forwarding-table
display multicast forwarding-table df-list
Use display multicast forwarding-table df-list to display information about the DF list in multicast forwarding entries.
display multicast forwarding-table df-list [ group-address ] [ verbose ] [ slot slot-number ]
verbose: Specifies detailed information about the DF list in multicast forwarding entries. If you do not specify this keyword, the command displays brief information about the DF list in multicast forwarding entries.
# Display brief information about the DF list in multicast forwarding entries.
<Sysname> display multicast forwarding-table df-list
00001. (0.0.0.0, 225.0.0.1)
       1: Vlan-interface1
# Display detailed information about the DF list in multicast forwarding entries.
<Sysname> display multicast forwarding-table df-list verbose
         1: Vlan-interface1
            Product information: 0x347849f6, 0x14bd6837
Table 8 Command output
Total number of forwarding entries, and the total number of matching entries.
00001
Sequence number of the entry.
(*, G) entry.
DF interface list.
display multicast routing-table
Use display multicast routing-table to display multicast routing entries.
display multicast routing-table [ source-address [ mask { mask-length | mask } ] | group-address [ mask { mask-length | mask } ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number ] *
incoming-interface: Specifies the multicast routing entries that contain the specified incoming interface.
outgoing-interface: Specifies the multicast routing entries that contain the specified outgoing interface.
exclude: Specifies the multicast routing entries that do not contain the specified interface in the outgoing interface list.
include: Specifies the multicast routing entries that contain the specified interface in the outgoing interface list.
match: Specifies the multicast routing entries that contain only the specified interface in the outgoing interface list.
Multicast routing entries are the basis of multicast forwarding. You can use this command to view the establishment state of (S, G) entries.
# Display multicast routing entries.
<Sysname> display multicast routing-table
 Total 1 entries
       Uptime: 00:00:28
       Upstream Interface: Vlan-interface1
      Backup Upstream Interface: Vlan-interface4
       List of 2 downstream interfaces
           1:  Vlan-interface2
           2:  Vlan-interface3
Table 9 Command output
Total 1 entries
Total number of (S, G) entries.
00001
(S, G) entry.
Uptime
Upstream Interface
Upstream interface at which (S, G) packets should arrive.
List of downstream interfaces that need to forward (S, G) packets.
reset multicast routing-table
display multicast routing-table static
Use display multicast routing-table static to display static multicast routing entries.
display multicast routing-table static [ source-address { mask-length | mask } ]
mask-length: Specifies an address mask length in the range of 0 to 32.
This command displays only valid static multicast routing entries.
# Display static multicast routing entries.
<Sysname> display multicast routing-table static
Destinations: 3        Routes: 4
Destination/Mask   Pre  RPF neighbor    Interface
1.1.0.0/16         10   7.12.0.1        Vlan12
                        7.11.0.1        Vlan11
2.2.2.0/24         20   7.11.0.1        Vlan11
3.3.3.3/32         50   7.12.0.1        Vlan12
Table 10 Command output
Destinations
Number of the multicast destination addresses.
Routes
Number of routes.
Destination/Mask
Destination address and its mask length.
Pre
Route preference.
RPF neighbor
IP address of the RPF neighbor to the reachable destination.
Outgoing interface to the reachable destination.
display multicast rpf-info
Use display multicast rpf-info to display RPF information for a multicast source.
display multicast rpf-info source-address [ group-address ]
# Display RPF information for multicast source 192.168.1.55.
<Sysname> display multicast rpf-info 192.168.1.55
 RPF information about source 192.168.1.55:
     RPF interface:Vlan-interface1, RPF neighbor: 10.1.1.1
     Backup RPF interface: Vlan-interface2, backup RPF neighbor: 2.2.2.2
     Referenced route/mask: 192.168.1.0/24
     Referenced route type: igp
     Load splitting rule: disable
     Source AS: 0
     C-multicast route target: 0x0000000000000000
Table 11 Command output
RPF neighbor
IP address of the RPF neighbor.
Referenced route and its mask length.
Type of the referenced route:
·     igp—IGP unicast route.
·     egp—EGP unicast route.
·     unicast (direct)—Directly connected unicast route.
·     unicast—Other unicast routes, such as static unicast route.
·     multicast static—Static multicast route.
·     mbgp—MBGP route.
Rule for RPF route selection:
·     Route preference.
·     Longest prefix match.
Load splitting rule
Status of the load splitting rule: enable or disable.
Source AS
AS number of the source-side PE.
Route target attribute value of the C-multicast route.
flow-policy (MRIB view)
Use flow-policy to create an IPv4 multicast flow policy and enter its view, or enter the view of an existing IPv4 multicast flow policy.
Use undo flow-policy to delete IPv4 multicast flow policies.
flow-policy { default | name policy-name }
undo flow-policy { all | default | name policy-name }
No IPv4 multicast flow policies exist.
MRIB view
all: Deletes all IPv4 multicast flow policies.
Operating mechanism
The device selects the link with the smallest bandwidth usage as the optimal link if the following conditions exist:
·     ECMP routes between the device and an upstream device.
·     The multicast load-splitting mode is flow-ucmp.
If two links have the same bandwidth usage, the link with the higher next-hop IP address is selected.
The bandwidth usage is calculated according to the following formula: Bandwidth usage = (Used bandwidth+Estimated bandwidth)/(Total interface bandwidth x (1–Unicast reserved bandwidth)).
·     The estimated bandwidth is configured by the bandwidth command in IPv4 multicast flow policy view.
·     The total interface bandwidth is configured by the bandwidth command in interface view.
·     The unicast reserved bandwidth is configured by the flow-ucmp unicast reserve-bandwidth or multicast flow-ucmp unicast reserve-bandwidth command.
For this command to take effect, you must configure the multicast load-splitting mode as flow-ucmp.
Adding, deleting, or modifying an IPv4 multicast flow policy does not affect the link selection results of existing multicast flows and affects link selection for only new multicast flows. Before configuring the multicast load-splitting mode as flow-ucmp, you must plan the configuration of an IPv4 multicast flow policy and the unicast reserved bandwidth configuration.
The change of link bandwidth and the change in the number of ECMP routes do not affect the route selection of existing multicast flows.
This feature does not affect multicast source-side link selection, link selection in PIM-DM, RPT link selection in PIM-SM, or local RP link selection.
If both IPv4 and IPv6 multicast flows exist in the network, increase the unicast reserved bandwidth as needed to avoid congestion.
# Create an IPv4 multicast flow policy named abc and enter its view.
# Create the default IPv4 multicast flow policy and enter its view.
[Sysname-mrib] flow-policy default
acl (IPv4 multicast flow policy)
bandwidth
flow-ucmp unicast reserve-bandwidth (MRIB view)
Use flow-ucmp unicast reserve-bandwidth to set the global IPv4 unicast reserved bandwidth percentage.
Use undo flow-ucmp unicast reserve-bandwidth to restore the default.
flow-ucmp unicast reserve-bandwidth percentage
The global IPv4 unicast reserved bandwidth percentage is not set.
MRIB view
percentage: Specifies the global IPv4 unicast reserved bandwidth percentage in the range of 1 to 100.
Execute this command when IPv4 unicast traffic and IPv4 multicast traffic coexist in the network. The available bandwidth for multicast traffic is calculated based on the total interface bandwidth and the configured IPv4 unicast reserved bandwidth percentage. For example, if the total interface bandwidth is 100 kbps and the unicast reserved bandwidth percentage is 20% (20 kbps), the available bandwidth for multicast traffic is 80 kbps.
The flow-ucmp unicast reserve-bandwidth command takes effect on all interfaces, and the multicast flow-ucmp unicast reserve-bandwidth command takes effect only on the current interface. If you execute both commands, the latter has higher priority.
Example
# Set the global IPv4 unicast reserved bandwidth percentage to 50%.
[Sysname-mrib] flow-ucmp unicast reserve-bandwidth 50
ip rpf-route-static
Use ip rpf-route-static to configure a static multicast route.
Use undo ip rpf-route-static to delete a static multicast route.
ip rpf-route-static source-address { mask-length | mask } { rpf-nbr-address | interface-type interface-number } [ preference preference ]
undo ip rpf-route-static source-address { mask-length | mask } { rpf-nbr-address | interface-type interface-number }
No static multicast routes exist.
rpf-nbr-address: Specifies an RPF neighbor by its IP address.
interface-type interface-number: Specifies an interface by its type and number. The interface connects the RPF neighbor.
preference: Sets a route preference in the range of 1 to 255. The default value is 1.
If the interface connected to an RPF neighbor is a point-to-point interface, you must specify the interface by its type and number.
If the interface connected to an RPF neighbor is not a point-to-point interface, you must specify the interface by its IP address. This type of interfaces includes Loopback and VLAN interfaces.
The configured static multicast route might not take effect when one of the following conditions exists:
·     The outgoing interface iteration fails.
·     The specified interface is not in the public network or the same VPN instance as the current interface.
·     The specified interface is not a point-to-point interface.
·     The specified interface is down.
If multiple static multicast routes within the same multicast source address range are available, only the one with the highest route preference can become active. You can use the display multicast routing-table static command to verify that the configured static multicast route has taken effect.
The undo ip rpf-route-static command deletes the specified static multicast route, but the delete ip rpf-route-static command deletes all static multicast routes.
# Configure a static multicast route to multicast source 10.1.1.0/24 and specify the interface with IP address 192.168.1.23 as the RPF neighbor.
[Sysname] ip rpf-route-static 10.1.1.0 24 192.168.1.23
load-splitting (MRIB view)
Use load-splitting to enable multicast load splitting.
Use undo load-splitting to restore the default.
load-splitting { balance-ecmp | balance-ucmp | ecmp | flow-ucmp | source | source-group | ucmp }
undo load-splitting
Multicast load splitting is disabled.
MRIB view
balance-ecmp: Enables multicast load balancing based on ECMP paths. Multicast traffic is evenly distributed among ECMP paths.
balance-ucmp: Enables multicast load balancing based on links. Multicast traffic is evenly distributed among links.
ecmp: Enables multicast load splitting based on ECMP paths.
flow-ucmp: Enables multicast load splitting based on the bandwidth usage of multicast flows.
source: Enables multicast load splitting based on multicast source.
source-group: Enables multicast load splitting based on multicast source and group.
ucmp: Enables multicast load splitting based on links.
This command does not take effect on BIDIR-PIM.
To use the flow-ucmp multicast load-splitting mode, you must first configure an IPv4 multicast flow policy and the IPv4 unicast reserved bandwidth percentage. Adding, deleting, or modifying an IPv4 multicast flow policy does not affect the link selection results of existing multicast flows and affects link selection for only new multicast flows.
On a network with ECMP routes, specify the balance-ecmp, ecmp, flow-ucmp, source, or source-group keyword. On a network with UCMP routes, specify the balance-ucmp or ucmp keyword.
·     If you specify the ecmp keyword, adding or deleting ECMP routes severely affects multicast forwarding.
·     If you specify the source or source-group keyword, adding or deleting ECMP routes slightly affects multicast forwarding. Specify either of the keywords on a network with unstable equal cost links.
·     If you specify the balance-ecmp or balance-ucmp keyword, the device uses a polling mechanism for multicast load balancing. ECMP or UCMP-based multicast load balancing provides better stability and balance than ECMP or UCMP-based multicast load sharing.
·     If you specify the flow-ucmp keyword, adding or deleting ECMP routes slightly affects multicast forwarding. Specify this keyword on a network with unstable equal-cost links. It provides better stability and balance than the ucmp multicast load-sharing mode.
# Enable multicast load splitting based on multicast source.
[Sysname-mrib] load-splitting source
longest-match (MRIB view)
Use longest-match to specify the longest prefix match principle for RPF route.
Use undo longest-match to restore the default.
longest-match
undo longest-match
Route preference is used for RPF route selection. The route with the highest preference is used as the RPF route.
MRIB view
This command enables the device to use the matching route with the longest prefix as the RPF route.
# Specify the longest prefix match principle for RPF route selection.
[Sysname-mrib] multicast longest-match
mtrace-service port
Use mtrace-service port to specify the UDP port number used by mtrace.
Use undo mtrace-service port to restore the default.
mtrace-service port number
Mtrace uses UDP port number 10240.
number: Specifies a UDP port number to be used by mtrace, in the range of 1024 to 49151.
Execute this command only when mtrace2 is used.
For successful mtrace, do not specify a UDP port number used by other modules.
You must specify the same UDP port number on all devices on the traced path. Additionally, the specified UDP port number must be the same as that specified in the mtrace v2 command.
# Specify 12345 as the UDP port number used by mtrace.
<Sysname> system-interview
[sysname] mtrace-service port 12345
mtrace v2
mtrace v1
Use mtrace v1 to trace a multicast path through mtrace1.
mtrace v1 { source-address | group-address } * [ destination address ] [ verbose ]
source-address: Specifies a multicast source by its IP address.
group-address: Specifies a multicast group by its IP address, in the range of 224.0.1.0 to 239.255.255.255.
destination address: Specifies the destination address of mtrace. The default destination address is 224.0.0.2.
verbose: Displays detailed information about mtrace. If you do not specify this keyword, the command displays brief information about mtrace.
To perform a non-group-specific mtrace, specify a multicast source and a destination. The mtrace starts from the destination and ends at the device directly connected to the multicast source.
To perform a non-source-specific mtrace, specify a multicast group and a destination. The mtrace starts from the destination and ends at the RP associated with the multicast group.
To perform a source-and-group-specific mtrace, specify both a multicast source and a multicast group. If you also specify a destination, the mtrace starts from the destination and ends at the device directly connected to the multicast source. If you do not specify a destination, the mtrace starts from the upstream device of the client and ends at the device directly connected to the multicast source.
An mtrace process stops if the number of traced hops reaches 255.
If the client does not receive a Reply message within 10 seconds, the client initiates a hop-by-hop mtrace to determine which device on the path encountered an error. It sends a Query message with the hops field set to 1 and waits for a Reply message. If it does not receive a Reply message within 10 seconds, the client determines that this hop encountered an error. If the client receives a Reply message within 10 seconds, it sends a Query message with the hops field value increased by 1 and waits for a Reply message. This process continues until the client does not receive a Reply message within the waiting time any more.
# Use mtrace1 to trace the path along which multicast data of group 225.2.1.1 travels from source 10.11.5.24 to destination 192.168.2.2 and display brief mtrace information.
<Sysname> mtrace v1 10.11.5.24 225.2.1.1 destination 192.168.2.2
 Mtrace from 10.11.5.24 to 192.168.2.2 via group 225.2.1.1, 255 hops at most, press
CTRL_C to break.
 Querying full reverse path...
  Hop  Incoming address  Outgoing address  Protocol       Time    Fwd code
    0  5.1.1.2           192.168.2.1       PIM            50 s    NO_ERROR
   -1  4.1.1.2           5.1.1.1           PIM            40 s    NO_ERROR
   -2  3.1.1.2           4.1.1.1           PIM            60 s    NO_ERROR
   -3  2.1.1.2           3.1.1.1           PIM            55 s    NO_ERROR
   -4  10.11.5.1         2.1.1.1           PIM            30 s    NO_ERROR
Table 12 Command output
Hop
Number of the hop. 0 represents the last hop, -1 represents the hop before the last hop, and so on.
Incoming address
Incoming interface of the multicast data.
Outgoing address
Outgoing interface of the multicast data.
Protocol
Multicast routing protocol used between this device and the previous-hop device:
·     PIM.
·     PIM(STATIC)—PIM using a static multicast route.
·     PIM(MBGP)—PIM using an MBGP route.
·     PIM(ASSERT)—PIM in a state created by Assert processing.
Time
Length of time used to transmit an mtrace message between this device and the previous-hop device, in seconds.
Fwd code
Forwarding code or error code:
·     NO_ERROR—No error.
·     WRONG_IF—The interface on which the mtrace message arrives is not in the outgoing interface list of the multicast data.
·     PRUNE_SENT—This device has sent a prune message to the upstream device.
·     PRUNE_RCVD—This device has received a prune message from the downstream device.
·     SCOPED—A multicast border is configured on the incoming interface or outgoing interface of the multicast data.
·     NO_ROUTE—This device does not have any route for the source or the RP.
·     WRONG_LAST_HOP—This device is not the proper last-hop device.
·     REACHED_RP—This device is the RP for the (*, G) multicast data.
·     RPF_IF—The mtrace message arrived on the expected RPF interface for the multicast data.
·     NO_MULTICAST—The mtrace message arrived on an interface that is not enabled with IP multicast.
·     NO_SPACE—No space is available for inserting a response data block in the packet.
# Use mtrace1 to trace the path along which multicast data of group 225.2.1.1 travels from source 10.11.5.24 to destination 192.168.2.2 and display detailed mtrace information.
<Sysname> mtrace v1 10.11.5.24 225.2.1.1 destination 192.168.2.2 verbose
 Mtrace from 10.11.5.24 to 192.168.2.2 via group 225.2.1.1, 255 hops at most, use query
 ID 12345, client port 50001, press CTRL_C to break.
 Querying full reverse path..........
Switching to hop-by-hop mode, Current hops: 2
    0: Incoming interface address: 4.1.1.2
       Outgoing interface address: 5.1.1.1
       Upstream router address: 4.1.1.1
       Input multicast packets: 111
       Output multicast packets: 111
       Forwarded packets for the (S, G) pair: 22
       Multicast protocol in use: PIM
       Multicast TTL threshold: 1
       Forwarding code: NO_ERROR
       Time used (s): 50
   -1: Incoming interface address: 3.1.1.2
       Outgoing interface address: 4.1.1.1
       Upstream router address: 3.1.1.1
       Forwarded Packets for the (S, G) pair: 22
       Time used (s): 50
Table 13 Command output
n
IP address of the upstream device.
Statistics for packets received on the incoming interface of the multicast data.
Statistics for packets forwarded through the outgoing interface of the multicast data.
Statistics for forwarded (S, G) packets.
Multicast routing protocol used on the traced path:
·     PIM.
Maximum number of hops to be traced on the interface.
Forwarding code
Time used (s)
Length of time for transmitting the mtrace message from the previous-hop device to this device.
mtrace v2
Use mtrace v2 to trace a multicast path through mtrace2.
mtrace v2 { source-address | group-address } * [ destination address | port number | wait-time time | max-hop count ] * [ verbose ]
port number: Specifies a UDP port number for mtrace2, in the range of 1024 to 49151. The default value is 10240.
wait-time time: Specifies the length of time that the client waits for a Reply message. The value range for the time argument is 1 to 65535 seconds and the default value is 10 seconds. If the client does not receive a Reply message within the waiting time, the client initiates a hop-by-hop mtrace.
max-hop count: Specifies the maximum number of the hops to be traced. The value range for the count argument is 1 to 255 and the default value is 255. If the maximum number of hops is reached on a device, the device directly sends an mtrace2 Reply message to the client and the mtrace is terminated.
To perform a non-group-specific mtrace, specify a multicast source and a destination. The mtrace starts from the destination and ends with the device directly connected to the multicast source.
An mtrace process stops if the maximum number of the hops to be traced is reached.
If the client does not receive a Reply message within the waiting time, the client initiates a hop-by-hop mtrace to determine which device on the path encountered an error. It sends a Query message with the hops field set to 1 and waits for a Reply message. If the client receives a Reply message within the waiting time, it sends a Query message with the hops field value increased by 1 and waits for a Reply message. This process continues until the client does not receive a Reply message within the waiting time any more.
# Use mtrace2 to trace the path along which multicast data of group 225.2.1.1 travels from source 10.11.5.24 to destination 192.168.2.2 and display brief mtrace information.
<Sysname> mtrace v2 10.11.5.24 225.2.1.1 destination 192.168.2.2
CTRL_C to break.
    0  5.1.1.2           192.168.2.1       PIM-SM(OSPF)   50 s    NO_ERROR
   -1  4.1.1.2           5.1.1.1           PIM-SM(OSPF)   40 s    NO_ERROR
   -2  3.1.1.2           4.1.1.1           PIM-SM(OSPF)   60 s    NO_ERROR
   -3  2.1.1.2           3.1.1.1           PIM-SM(OSPF)   55 s    NO_ERROR
   -4  10.11.5.1         2.1.1.1           PIM-SM(OSPF)   30 s    NO_ERROR
Table 14 Command output
Hop
Incoming address
Outgoing address
Protocol
·     PIM-SM.
·     PIM-DM.
Unicast routing protocol used between this device and the previous-hop device:
·     LOCAL—Direct route.
·     STATIC ROUTE—Static route.
·     RIP.
·     ISIS.
·     OSPF.
·     BGP.
Time
Fwd code
# Use mtrace2 to trace the path along which multicast data of group 225.2.1.1 travels from source 10.11.5.24 to destination 192.168.2.2 and display detailed mtrace information.
<Sysname> mtrace v2 10.11.5.24 225.2.1.1 destination 192.168.2.2 verbose
 Mtrace from 10.11.5.24 to 192.168.2.2 via group 225.2.1.1, 255 hops at most, use query ID 12345, client port 50001, press CTRL_C to break.
       Multicast protocol in use: PIM-SM
       Unicast protocol in use: OSPF
       Time used (s): 50
       Time used (s): 50
Table 15 Command output
n
Statistics of packets received on the incoming interface of the multicast data.
Statistics of packets forwarded through the outgoing interface of the multicast data.
Statistics of forwarded (S, G) packets.
Multicast routing protocol running on the incoming interface of the multicast data.
Unicast routing protocol running on the incoming interface of the multicast data.
Forwarding code
Time used (s)
mtrace-service port
multicast boundary
Use multicast boundary to configure a multicast forwarding boundary.
Use undo multicast boundary to delete a multicast forwarding boundary.
undo multicast boundary { group-address { mask-length | mask } | all }
No multicast forwarding boundaries are configured on an interface.
Interface view
all: Specifies all forwarding boundaries configured on the interface.
A multicast forwarding boundary sets the boundary condition for the multicast groups in the specified address range. If the destination address of a multicast packet matches the set boundary condition, the packet is not forwarded.
You can configure an interface as a multicast forwarding boundary for different multicast group ranges by executing this command multiple times on the interface.
You do not need to enable IP multicast routing before you execute this command.
Assume that Set A and Set B are multicast forwarding boundary sets with different address ranges, and B is a subset of A. A takes effect on the interface no matter whether A is configured earlier or later than B.
# Configure VLAN-interface 100 as the forwarding boundary of multicast groups in the range of 239.2.0.0/16.
[Sysname-Vlan-interface100] multicast boundary 239.2.0.0 16
multicast cpu-forwarding max-copy-count
Use multicast cpu-forwarding max-copy-count to set the maximum number of copied multicast packets during software forwarding.
Use undo multicast cpu-forwarding max-copy-count to restore the default.
multicast cpu-forwarding max-copy-count count
The maximum number of copied multicast packets during software forwarding is 5.
count: Specifies the maximum number of copied multicast packets during software forwarding. The value range for this argument is 1 to 5.
Setting a greater limit will cause high CPU usage and degrade forwarding performance. Setting a small limit will cause multicast packets to be dropped.
CAUTION
CAUTION:
Perform this task under the guidance of H3C Support.
# Set the maximum number to 3 for copied multicast packets during software forwarding.
[Sysname] multicast cpu-forwarding max-copy-count 3
Use multicast flow-ucmp unicast reserve-bandwidth to set the IPv4 unicast reserved bandwidth percentage on an interface.
Use undo multicast flow-ucmp unicast reserve-bandwidth to restore the default.
multicast flow-ucmp unicast reserve-bandwidth percentage
The IPv4 unicast reserved bandwidth percentage is not set on an interface.
Interface view
percentage: Specifies the IPv4 unicast reserved bandwidth percentage in the range of 1 to 100.
For this command to take effect, you must use the load-splitting command to configure the multicast load-splitting mode.
Example
# Set the IPv4 unicast reserved bandwidth percentage to 50% on VLAN interface 100.
[Sysname-Vlan-interface100] multicast flow-ucmp unicast reserve-bandwidth 50
multicast forwarding-table cache-unknown per-entry
Use multicast forwarding-table cache-unknown per-entry to set the maximum number of unknown multicast packets that can be cached for an (S, G) entry.
Use undo multicast forwarding-table cache-unknown per-entry to restore the default.
multicast forwarding-table cache-unknown per-entry per-entry-limit
The device can cache only one unknown multicast packet for an (S, G) entry.
per-entry-limit: Specifies the maximum number of unknown multicast packets that can be cached for an (S, G) entry. The value range for this argument is 0 to 256. If you set the value to 0, the device cannot cache unknown multicast packets.
# Set the maximum number to 20 for unknown multicast packets that can be cached for an (S, G) entry.
[Sysname] multicast forwarding-table cache-unknown per-entry 20
multicast forwarding-table cache-unknown total
Use multicast forwarding-table cache-unknown total to set the maximum number of all unknown multicast packets that can be cached.
Use undo multicast forwarding-table cache-unknown total to restore the default.
multicast forwarding-table cache-unknown total total-limit
The device can cache 1024 unknown multicast packets in total.
total-limit: Specifies the maximum number of all unknown multicast packets that can be cached. The value range for this argument is 0 to 65535. If you set the value to 0, the device cannot cache unknown multicast packets.
As a best practice, set the value in this command to be far greater than the value set in the multicast forwarding-table cache-unknown per-entry command.
# Set the maximum number to 10000 for all unknown multicast packets that can be cached.
[Sysname] multicast forwarding-table cache-unknown total 10000
multicast permit ssdp-group
Use multicast permit ssdp-group to allow the generation of multicast entries with group address 239.255.255.250.
Use undo multicast permit ssdp-group to restore the default.
The device cannot generate multicast entries with 239.255.255.250 as the group address.
By default, the device cannot generate multicast entries with 239.255.255.250 as the group address. Perform this task to allow multicast entries with 239.255.255.250 as the group address to be generated on the device.
The generation of multicast entries with 239.255.255.250 as the group address is also affected by a multicast group policy and a multicast source policy. If 239.255.255.250 is filtered by the ACL in a multicast group policy or multicast source policy, such multicast entries cannot be generated. A multicast group policy is configured by using the igmp group-policy command, and a multicast source policy is configured by using the source-policy command.
# Allow the generation of multicast entries with group address 239.255.255.250.
[Sysname] multicast permit ssdp-group
multicast routing
Use multicast routing to enable IP multicast routing and enter MRIB view.
Use undo multicast routing to disable IP multicast routing.
multicast routing
IP multicast routing is disabled.
Other Layer 3 multicast commands take effect only when IP multicast routing is enabled.
The device does not forward multicast packets before IP multicast routing is enabled.
# Enable IP multicast routing, and enter MRIB view.
[Sysname-mrib]
Use reset multicast fast-forwarding cache to clear multicast fast forwarding entries.
reset multicast fast-forwarding cache { { source-address | group-address } * | all } [ slot slot-number ]
all: Specifies all multicast fast forwarding entries.
# Clear all multicast fast forwarding entries.
<Sysname> reset multicast fast-forwarding cache all
# Clear the multicast fast forwarding entry for multicast source and group (20.0.0.2, 225.0.0.2).
<Sysname> reset multicast fast-forwarding cache 20.0.0.2 225.0.0.2
Use reset multicast forwarding event to clear statistics for multicast forwarding events.
# Clear statistics for multicast forwarding events.
<Sysname> reset multicast forwarding event
Use reset multicast forwarding-table to clear multicast forwarding entries.
reset multicast forwarding-table { { source-address [ mask { mask-length | mask } ] | group-address [ mask { mask-length | mask } ] | incoming-interface { interface-type interface-number } } * | all }
all: Specifies all multicast forwarding entries.
When you clear a multicast forwarding entry, the associated multicast routing entry is also cleared.
# Clear multicast forwarding entries for multicast group 225.5.4.3.
<Sysname> reset multicast forwarding-table 225.5.4.3
Use reset multicast routing-table to clear multicast routing entries.
reset multicast routing-table { { source-address [ mask { mask-length | mask } ] | group-address [ mask { mask | mask-length } ] | incoming-interface interface-type interface-number } * | all }
incoming-interface: Specifies the routing entries that contain the specified incoming interface.
all: Specifies all multicast routing entries.
When you clear a multicast routing entry, the associated multicast forwarding entry is also cleared.
# Clear multicast routing entries for multicast group 225.5.4.3.
<Sysname> reset multicast routing-table 225.5.4.3
