11-MPLS
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesMIB CompanionH3C SR8800-F Routers MIB Reference-R838x-6W10011-MPLS
12-HH3C-MPLSSLSP-MIB
12-HH3C-MPLSSLSP-MIB 44.41 KB
HH3C-MPLSSLSP-MIB
About this MIB
Use this MIB to notify static LSP traps.
MIB file name
hh3c-mplsslsp.mib
Notifications
hh3cMplsSlspDown
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.230.0.1
Static LSP down
Error
Major
1.3.6.1.4.1.25506.2.230.0.2 (hh3cMplsSlspUp)
OFF
Notification triggers
This notification might be generated when the following events occur:
MPLS disabled on an interface.
Route change.
Inbound interface Down.
Outbound interface Down.
Static LSP configuration updated.
Others.
System impact
Service interruption will occur on services that use the static LSP for traffic forwarding.
No negative impact will occur on services that do not use the static LSP for traffic forwarding.
Status control
ON
CLI: Use the snmp-agent trap enable mpls-private slsp-up-down command.
OFF
CLI: Use the undo snmp-agent trap enable mpls-private slsp-up-down command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.230.1.1.1 (hh3cMplsSlspBaseInfo)
Static LSP basic information
N/A
OCTET STRING
As per the MIB.
1.3.6.1.4.1.25506.2.230.1.1.2 (hh3cMplsSlspExtInfo)
Static LSP extended information
N/A
OCTET STRING
As per the MIB.
Recommended action
To resolve this issue:
1.Execute the display mpls interface command to check interface information.
If the alarm was generated at the ingress of the static LSP, check the outgoing interface. If the alarm was generated at the egress of the static LSP, check the incoming interface. If the alarm was generated at the transit node of the static LSP, check both the incoming interface and outgoing interface.
In the command output, verify that the corresponding interface exists and the interface status is Up.
  - If the interface status is not Up, check and correct the interface configuration, and then go to step 2.
  - If the corresponding interface is not displayed in the command output, it indicates that MPLS is not enabled on the interface. Enable MPLS on the interface and then go to step 2.
2.Execute the display ip routing-table ip-address command at the ingress node, and check whether a valid route exists.
  - If yes, go to step 3.
  - If not, check the route configuration and ensure that the next hop address is reachable. Then, go to step 4.
3.Execute the display mpls lsp command at the ingress node to check whether a dynamic LSP with the same prefix as the static LSP is configured.
  - If yes, disable the dynamic LSP and go to step 4.
  - If not, go to step 5.
4.Check whether the alarms have been cleared.
  - If yes, the issue has been resolved.
5.Collect alarm information and configuration data, and then contact Technical Support for help.
hh3cMplsSlspUp
Basic information
OID
Event
Severity
Default status
Static LSP up
Recovery
Warning
N/A (N/A)
OFF
This notification is generated when a static LSP comes up.
System impact
No negative impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
N/A
OCTET STRING
As per the MIB.
Recommended action
No action is required.
