11-MPLS
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesMIB CompanionH3C SR8800-F Routers MIB Reference-R838x-6W10011-MPLS
06-HH3C-MPLS-LDP-MIB
06-HH3C-MPLS-LDP-MIB 48.14 KB
HH3C-MPLS-LDP-MIB
About this MIB
This MIB contains MPLS LDP notifications.
MIB file name
hh3c-mpls-ldp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3cMpls(12).hh3cMplsLdp(2)
Scalar objects
hh3cMplsLdpCfgInfo (1.3.6.1.4.1.25506.8.12.2.3.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
OCTET STRING
OCTET STRING (1..127)
LDP configuration information
As per the MIB
hh3cMplsLdpSessInfo (1.3.6.1.4.1.25506.8.12.2.3.2)
Object (OID)
Access
Value range
Implementation
OCTET STRING
LDP session information
As per the MIB
Notifications
hh3cMplsLdpMulLinkCfgInc
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.8.12.2.2.0.17
LDP multi-link configuration inconsistency
Error
Major
1.3.6.1.4.1.25506.8.12.2.2.0.18 (hh3cMplsLdpMulLinkCfgIncClear)
OFF
Notification triggers
If multiple links exist between LDP peers, the system compares the LDP parameters configured on the interfaces of the links and the targeted peer with the LDP parameters negotiated. If the LDP parameter settings are inconsistent, the system generates a notification.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable ldp-private command.
OFF
CLI: undo snmp-agent trap enable ldp-private command.
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
N/A
OCTET STRING
As per the MIB.
Recommended action
1.Check whether the keepalive-hold value configured in interface view or LDP peer view (targeted-peer) is consistent with that selected after the LDP session negotiation. If they are inconsistent, change the keepalive-hold setting on the interfaces or targeted-peer to the negotiated value.
2.Check whether the transport-address value configured in interface view or LDP peer view (targeted-peer) is consistent with that selected after the LDP session negotiation. If they are inconsistent, change the transport-address setting on the interfaces or targeted-peer to the negotiated value.
3.If the issue persists, contact Technical Support for help.
Basic information
OID
Event
Severity
Default status
LDP multi-link configuration inconsistency cleared
Recovery
Warning
N/A (N/A)
OFF
This notification is generated when the LDP multi-link configuration inconsistency is removed.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
N/A
OCTET STRING
As per the MIB.
Recommended action
No action is required.
