11-MPLS
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesMIB CompanionH3C SR8800-F Routers MIB Reference-R838x-6W10011-MPLS
02-HH3C-MPLSLSPV-MIB
02-HH3C-MPLSLSPV-MIB 44.37 KB
HH3C-MPLSLSPV-MIB
About this MIB
Use this MIB to implement LSPV trap notification.
MIB file name
hh3c-mplslspv.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMplsLspv(241)
Scalar objects
hh3cMplsLspvBaseInfo (1.3.6.1.4.1.25506.2.241.1.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
OCTET STRING
OCTET STRING (0..127)
LSPV basic information.
As per the MIB.
Notifications
hh3cMplsLspvPingProbe
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.241.0.1
LSP ping notification.
Informational
Major
N/A (N/A)
ON
Notification triggers
This notification is generated when the device receives LSP ping packets and the reply mode is no reply.
System impact
No negative impact on the system.
Status control
None.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.241.1.1.1 (hh3cMplsLspvBaseInfo)
N/A
OCTET STRING
Standard MIB values.
Recommended action
No action is required.
hh3cMplsLspvTracertProbe
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.241.0.2
LSP tracert notification.
Informational
Major
N/A (N/A)
ON
This notification is generated when the device receives LSP tracert packets and the reply mode is no reply.
System impact
Status control
None.
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
Recommended action
