19-High Availability
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R838x-6W10019-High Availability
08-HH3C-STRUNK-MIB
08-HH3C-STRUNK-MIB 56.01 KB
HH3C-STRUNK-MIB
About this MIB
This MIB is defined to obtain S-Trunk configuration information and send notifications upon S-Trunk state changes.
MIB file name
hh3c-strunk.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cStrunk(208)
Scalar objects
hh3cStrunkMemberId
(1.3.6.1.4.1.25506.2.208.1.1.2)
Object (OID)
Access
Value range
Implementation
hh3cStrunkMemberId
accessible-for-notify
Integer32
bagg(1),
ragg(2)
Member ID.
Supported
hh3cStrunkMemberStatus (1.3.6.1.4.1.25506.2.208.1.1.3)
Object (OID)
Access
Value range
Implementation
Integer32
primary(1),
secondary(2)
Member status.
Supported
hh3cStrunkMemberReason (1.3.6.1.4.1.25506.2.208.1.1.4)
Object (OID)
Access
Value range
Implementation
OCET STRING
STRING(SIZE(0..255))
Reason for member status change.
Supported
hh3cStrunkGroupId (1.3.6.1.4.1.25506.2.208.1.1.5)
Object (OID)
Access
Value range
Implementation
Integer32
Standard MIB values.
Group ID.
Supported
hh3cStrunkGroupStatus
(1.3.6.1.4.1.25506.2.208.1.1.6)
Object (OID)
Access
Value range
Implementation
Integer32
init(1)
primary(2)
secondary(3)
Reason for group status change.
Supported
hh3cStrunkGroupReason
(1.3.6.1.4.1.25506.2.208.1.1.7)
Object (OID)
Access
Value range
Implementation
OCTET STRING
Group status.
Supported
Notifications
hh3cStrunkMemberStatusChange
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.208.1.0.1
The S-Trunk member role of the device changes.
Informational
Warning
ON
Notification triggers
This notification is generated when the S-Trunk member role of the device changes.
System impact
If the S-Trunk member role of the device changes to primary, the device can forward data.
If the S-Trunk member role of the device changes to secondary, the device cannot forward data.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.208.1.1.1
 (hh3cStrunkMemberType)
Member type.
N/A
Integer32
bagg(1),, ragg(2)
 (hh3cStrunkMemberId)
Member ID.
N/A
Integer32
 (hh3cStrunkMemberStatus)
Member status.
N/A
Integer32
primary(1),, secondary(2)
1.3.6.1.4.1.25506.2.208.1.1.4 (hh3cStrunkMemberReason)
N/A
OCTET STRING
Recommended action
No action is required.
hh3cStrunkStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.208.1.0.2
The status of the S-Trunk group changes.
Informational
Warning
ON
This notification is generated when the status of the S-Trunk group changes.
System impact
No impact on the system.
Status control
Object
OID (object name)
Index
Value range
 (hh3cStrunkGroupId)
Group ID.
N/A
Integer32
 (hh3cStrunkGroupStatus)
Group status.
N/A
Integer32
init(1), primary(2), secondary(3)
1.3.6.1.4.1.25506.2.208.1.1.7 (hh3cStrunkGroupReason)
N/A
OCTET STRING
Recommended action
