19-High Availability
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R838x-6W10019-High Availability
06-HH3C-RDDC-MIB
06-HH3C-RDDC-MIB 87.73 KB
HH3C-RDDC-MIB
About this MIB
This MIB is defined to obtain redundancy group configuration information and send notifications upon redundancy group state changes.
MIB file name
hh3c-rddc.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cRddc(151)
Scalar objects
hh3cRddcNodeInfo(1.3.6.1.4.1.25506.2.151.1.2.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
DisplayString
(0..255)
Node information in the notification.
As per the MIB.
hh3cRddcSwitchReason
(1.3.6.1.4.1.25506.2.151.1.2.2)
Object (OID)
Access
Value range
Implementation
DisplayString
(0..255)
Switchover reason in the notification.
As per the MIB.
Tabular objects
hh3cRddcTable
About this table
This table contains redundancy group information.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cRddcGroupIdx.
Object (OID)
Access
Value range
Implementation
hh3cRddcGroupIdx (1.3.6.1.4.1.25506.2.151.1.1.1.1.1)
Unsigned32
Standard MIB values.
Redundancy group ID.
As per the MIB.
hh3cRddcGroupName (1.3.6.1.4.1.25506.2.151.1.1.1.1.2)
read-only
DisplayString
SIZE (1..16)
Redundancy group name.
As per the MIB.
hh3cRddcPreempTimeRemain
(1.3.6.1.4.1.25506.2.151.1.1.1.1.3)
read-only
Unsigned32
Remaining preemption delay time of the redundancy group.
As per the MIB.
hh3cRddcPreempTimeConfig
(1.3.6.1.4.1.25506.2.151.1.1.1.1.4)
read-only
Unsigned32
Configured preemption delay timer of the redundancy group.
As per the MIB.
hh3cRddcHoldTimeRemain
(1.3.6.1.4.1.25506.2.151.1.1.1.1.5)
read-only
Unsigned32
Remaining hold-down time of the redundancy group.
As per the MIB.
hh3cRddcHoldTimeConfig
(1.3.6.1.4.1.25506.2.151.1.1.1.1.6)
read-only
Unsigned32
Configured hold-down timer of the redundancy group.
As per the MIB.
hh3cRddcNodeTable
About this table
This table contains configuration and state information about a redundancy group.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cRddcNodeGroupIdx and hh3cRddcNodeId.
Object (OID)
Access
Value range
Implementation
hh3cRddcNodeGroupIdx (1.3.6.1.4.1.25506.2.151.1.1.2.1.1)
not-accessible
Unsigned32
As per the MIB.
hh3cRddcNodeId (1.3.6.1.4.1.25506.2.151.1.1.2.1.2)
not-accessible
Unsigned32
Redundancy group node ID.
As per the MIB.
hh3cRddcNodeBindType
(1.3.6.1.4.1.25506.2.151.1.1.2.1.3)
read-only
INTEGER
Binding type of the redundancy group, invalid(1) or chassis(2).
As per the MIB.
hh3cRddcNodeBindInfo (1.3.6.1.4.1.25506.2.151.1.1.2.1.4)
read-only
Unsigned32
Binding information of the redundancy group node. Only chassis binding is supported.
As per the MIB.
hh3cRddcNodePriority (1.3.6.1.4.1.25506.2.151.1.1.2.1.5)
read-only
Unsigned32
1..255
Priority of the redundancy group node.
As per the MIB.
hh3cRddcNodeWeight (1.3.6.1.4.1.25506.2.151.1.1.2.1.6)
read-only
Integer32
Weight of the redundancy group node. The default and maximum weight values are both 255.
As per the MIB.
hh3cRddcNodeStatus (1.3.6.1.4.1.25506.2.151.1.1.2.1.7)
read-only
INTEGER
State of the redundancy group node. Supported values are invalid(1), master(2), and standby(3).
As per the MIB.
Notifications
hh3cRddcSwitchoverTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.151.0.1
This notification is generated when a switchover occurs in the redundancy group.
Informational
Minor
N/A (N/A)
ON
Notification triggers
System impact
No impact on services. Services automatically migrate between the redundancy group nodes.
Status control
ON
CLI: Use the snmp-agent trap enable rddc command.
OFF
CLI: Use the undo snmp-agent trap enable rddc command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.151.1.1.1.1.1 (hh3cRddcGroupIdx)
Redundancy group index.
hh3cRddcGroupIdx
Unsigned32
0..255
1.3.6.1.4.1.25506.2.151.1.1.1.1.2 (hh3cRddcGroupName)
hh3cRddcGroupIdx
DisplayString
OCTET STRING (SIZE (1..16))
1.3.6.1.4.1.25506.2.151.1.2.1 (hh3cRddcNodeInfo)
Redundancy group node information.
N/A
DisplayString
OCTET STRING(SIZE (0..255)), "No chassis is active", "Chassis-chassis id is active"
1.3.6.1.4.1.25506.2.151.1.2.2 (hh3cRddcSwitchReason)
Switchover reason.
N/A
DisplayString
OCTET STRING(SIZE (0..255)), "manual switchover",, "group's configuration changed",, "node's weight changed"
Recommended action
To resolve this issue:
1.Execute the display redundancy group command to identify the cause of the switchover.
2.Resolve the cause and verify that the redundancy group nodes operate correctly.
hh3cRddcFailIfRecoverTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.151.0.2
This notification is generated when the failed interface in the redundancy group recovers.
Recovery
Warning
N/A (N/A)
ON
System impact
Services are resumed on the recovered interface.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cRddcGroupIdx
Unsigned32
0..255
hh3cRddcGroupIdx
DisplayString
OCTET STRING(SIZE (1..16))
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Index of the failed interface.
ifIndex
InterfaceIndex
Integer32 (1..2147483647)
1.3.6.1.2.1.2.2.1.2 (ifDescr)
Description of the failed interface.
ifIndex
DisplayString
Recommended action
No action is required.
hh3cRddcFailIfGenerateTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.151.0.3
This notification is generated when the interface associated with the redundancy group fails.
Error
Major
1.3.6.1.4.1.25506.2.151.0.2 (hh3cRddcFailIfRecoverTrap)
ON
System impact
Services on the failed interface are affected.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cRddcGroupIdx
Unsigned32
0..255
hh3cRddcGroupIdx
DisplayString
ifIndex
InterfaceIndex
ifIndex
DisplayString
Recommended action
To resolve the issue:
1.Execute the display redundancy group command to check whether a track entry is associated with the redundancy group:
  - If yes, go to step 2.
  - If no, go to step 3.
2.Execute the display track command to identify the cause of interface failure and resolve the cause. After the track entry becomes positive, check the state of this alarm:
  - If the alarm is cleared, no action is required.
  - If the alarm persists, go to step 4.
3.Examine the cause of the interface down state and resolve the cause. After the interface comes up, check the state of this alarm:
4.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
