05-HH3C-ETHOAM-MIB | 43.81 KB |
HH3C-ETHOAM-MIB
About this MIB
This MIB is a private MIB to implement Ethernet OAM functions.
MIB file name
hh3c-ethoam.mib
Notifications
hh3cEthoamNonThresholdRecovery
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.227.1.0.1 |
The alarm for a non-threshold-crossing event is cleared. |
Recovery |
Warning |
N/A (N/A) |
ON |
Notification triggers
This notification is generated when a non-threshold-crossing event is cleared on the local or remote end.
System impact
No negative impact on the system.
Status control
The notification cannot be disabled.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
Interface index |
ifIndex |
Integer32 |
Integer32 (1..2147483647) |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
Interface name |
ifIndex |
OCTET STRING |
OCTET STRING (0..255) |
1.3.6.1.2.1.158.1.6.1.2 (dot3OamEventLogTimestamp) |
Timestamp of the event. |
ifIndex dot3OamEventLogIndex |
TimeStamp |
TimeTicks |
1.3.6.1.2.1.158.1.6.1.3 (dot3OamEventLogOui) |
OUI of the event packet. |
EightOTwoOui |
OCTET STRING (SIZE (1..255)) |
1.3.6.1.2.1.158.1.6.1.4 (dot3OamEventLogType) |
Event type. |
Unsigned32 |
linkFault(256), dyingGaspEvent(257), criticalLinkEvent(258) |
1.3.6.1.2.1.158.1.6.1.5 (dot3OamEventLogLocation) |
Whether the event is a local event or a peer event. |
INTEGER |
local(1), remote(2) |
1.3.6.1.2.1.158.1.6.1.12 (dot3OamEventLogTimestamp) |
Total number of times the event has occurred. |
Unsigned32 |
Standard MIB values. |
Recommended action
No action is required.
hh3cEthoamLoopbackFailed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.227.1.0.2 |
Loopback detection failed to be enabled on an interface. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when loopback detection fails to be enabled on an interface.
System impact
Remote loopback cannot be enabled, affecting link diagnosis.
Status control
Object
OID (object name) |
Index |
Type |
Value range |
Interface index |
ifIndex |
Integer32 |
Interface name |
ifIndex |
OCTET STRING |
Recommended action
To resolve the issue:
1.Check whether the remote port rejects the Ethernet OAM remote loopback request from the local port.
Execute the display current-configuration command on the remote device to check whether the oam remote-loopback reject-request command has been configured.
- If that command has been configured, execute the undo oam remote-loopback reject-request command to accept the Ethernet OAM remote loopback request from the local port. Then go to step 2.
- If that command has not been configured, go to step 3.
2.Check whether the issue has been resolved. If the issue persists, go to step 3.
3.Execute the display oam remote command to display Ethernet OAM connection information for the remote port.
- If the value of the OAM mode field is Active, go to step 5.
- If the value of the OAM mode field is Active, go to step 4.
4.Ensure that the physical link is normal. For more information, see physical connection troubleshooting methods.
5.Collect log messages and configuration data, and then contact H3C Support for help.
