19-High Availability
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R838x-6W10019-High Availability
04-HH3C-DLDP2-MIB
04-HH3C-DLDP2-MIB 88.93 KB
HH3C-DLDP2-MIB
About this MIB
HH3C-DLDP2-MIB is a private MIB used to implement network management on the DLDP feature. Use this MIB to enable DLDP globally or on a port, and obtain port running state information, link state information, and DLDP neighbor information.
MIB file name
hh3c-dldp2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cDldp2(117)
Scalar objects
hh3cDldp2GlobalEnable
(1.3.6.1.4.1.25506.2.117.1.1)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1),
false(2)
Whether DLDP is enabled globally.
As per the MIB.
hh3cDldp2Interval
(1.3.6.1.4.1.25506.2.117.1.2)
Object (OID)
Access
Value range
Implementation
hh3cDldp2Interval
read-write
Integer32
Integer32(1..100)
Advertisement packet sending interval.
As per the MIB.
hh3cDldp2AuthMode
(1.3.6.1.4.1.25506.2.117.1.3)
Object (OID)
Access
Value range
Implementation
hh3cDldp2AuthMode
read-write
INTEGER
unknown(1),
none(2),
simple(3),
md5(4)
Authentication mode.
As per the MIB.
hh3cDldp2AuthPassword
(1.3.6.1.4.1.25506.2.117.1.4)
Object (OID)
Access
Value range
Implementation
read-write
OCTET STRING
OCTET STRING (0..16)
Authentication password.
As per the MIB.
hh3cDldp2UniShutdown
(1.3.6.1.4.1.25506.2.117.1.5)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
unknown(1),             auto(2),                    manual(3)
Port shutdown mode on detecting a unidirectional link.
As per the MIB.
Tabular objects
hh3cDldp2PortConfigTable
About this table
Use this table to enable DLDP on a port and obtain DLDP port configuration information.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cDldp2PortEnable
(1.3.6.1.4.1.25506.2.117.2.1.1.1)
read-write
TruthValue
true(1),
false(2)
Whether DLDP is enabled on the port.
As per the MIB.
hh3cDldp2PortStatusTable
About this table
Use this table to obtain DLDP port state and link state information.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDldp2PortOperStatus
(1.3.6.1.4.1.25506.2.117.2.2.1.1)
read-only
INTEGER
unknown(1),                   initial(2),             inactive(3),               unidirectional(4),                  bidirectional(5)
Port state.
As per the MIB.
hh3cDldp2PortLinkStatus
(1.3.6.1.4.1.25506.2.117.2.2.1.2)
read-only
INTEGER
unknown(1),
down(2),
up(3)
Link state.
As per the MIB.
hh3cDldp2NeighborTable
About this table
Use this table to obtain neighbor information about a port.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ifIndex, hh3cDldp2NeighborBridgeMac, and hh3cDldp2NeighborPortIndex.
Object (OID)
Access
Value range
Implementation
hh3cDldp2NeighborBridgeMac (1.3.6.1.4.1.25506.2.117.2.3.1.1)
not-accessible
MacAddress
OCTET STRING (6)
Bridge MAC address of the neighbor.
As per the MIB.
hh3cDldp2NeighborPortIndex(1.3.6.1.4.1.25506.2.117.2.3.1.2)
not-accessible
Integer32
Integer32(1..2147483647)
Port index of the neighbor.
As per the MIB.
hh3cDldp2NeighborStatus (1.3.6.1.4.1.25506.2.117.2.3.1.3)
read-only
INTEGER
unknown(1),            unconfirmed(2),                  confirmed(3)
State of the neighbor.
As per the MIB.
hh3cDldp2NeighborAgingTime (1.3.6.1.4.1.25506.2.117.2.3.1.4)
read-only
Integer32
Standard MIB values.
Aging time of the neighbor.
As per the MIB.
Notifications
hh3cDldp2TrapUniLink
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.117.4.0.1
DLDP detects unidirectional links.
Error
Critical
1.3.6.1.4.1.25506.2.117.4.0.2 (hh3cDldp2TrapBidLink)
ON
Notification triggers
This notification is generated when DLDP detects a unidirectional link.
System impact
Service traffic cannot be transmitted correctly on a unidirectional link.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Interface index.
ifInex
InterfaceIndex
1..2147483647
1.3.6.1.2.1.2.2.1.2 (ifDescr)
Interface description.
ifInex
DisplayString
OCTET STRING (SIZE (0..255))
Recommended action
To resolve the issue:
1.Shut down the port, and recover the unidirectional link.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
DLDP detects bidirectional links.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when DLDP detects a bidirectional link.
System impact
No impact on services.
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
InterfaceIndex
1..2147483647
ifIndex
DisplayString
Recommended action
No action is required.
