03-HH3C-CFD-MIB | 129.62 KB |
(1.3.6.1.4.1.25506.2.207.1.1.1)
(1.3.6.1.4.1.25506.2.207.1.1.2 )
hh3cCfdTimeThreshold (1.3.6.1.4.1.25506.2.207.1.1.3)
hh3cCfdFrameEnd (1.3.6.1.4.1.25506.2.207.1.1.4)
hh3cCfdStatisticThreshold (1.3.6.1.4.1.25506.2.207.1.1.5)
hh3cCfdExceptionMACStatusClear
HH3C-CFD-MIB
About this MIB
This MIB describes extended CFD table entries.
MIB file name
hh3c-cfd.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cCfd(207)
Scalar objects
hh3cCfdMepId
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCfdMepId (1.3.6.1.4.1.25506.2.207.1.1.1) |
accessible-for-notify |
Integer32 |
Interger(1..8191) |
MEP ID. |
Supported |
hh3cCfdSrvId
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCfdSrvId (1.3.6.1.4.1.25506.2.207.1.1.2 ) |
Integer32 |
Integer(0..32767) |
Service instance ID. |
Supported |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCfdTimeThreshold (1.3.6.1.4.1.25506.2.207.1.1.3) |
Integer32 |
Standard MIB values. |
Configured threshold. |
Supported |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCfdFrameEnd (1.3.6.1.4.1.25506.2.207.1.1.4) |
Integer32 |
nearEnd(1) farEnd(2) |
Detection frame direction. |
Supported |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCfdStatisticThreshold (1.3.6.1.4.1.25506.2.207.1.1.5) |
OCTET STRING |
STRING(SIZE(0..8)) |
Configured frame loss threshold. |
Supported |
Notifications
hh3cCfdTwowayDelay
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.207.1.0.1 |
The two-way delay exceeds the upper limit. |
Error |
Critical |
1.3.6.1.4.1.25506.2.207.1.0.2 (hh3cCfdTwowayDelayRecovery) |
ON |
Notification triggers
This notification is generated when the two-way delay reaches or exceeds the configured upper limit for three consecutive times.
System impact
The link delay is high.
Status control
This notification cannot be disabled.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.207.1.1.1 (hh3cCfdMepId) |
MEP ID. |
N/A |
Integer32 |
Interger(1..8191) |
1.3.6.1.4.1.25506.2.207.1.1.2 (hh3cCfdSrvId) |
N/A |
Integer32 |
Integer(0..32767) |
1.3.6.1.4.1.25506.2.207.1.1.3 (hh3cCfdTimeThreshold) |
N/A |
Integer32 |
Recommended action
Check whether excessive service traffic exists in the network.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.207.1.0.2 |
The two-way delay threshold alarm is recovered. |
Recovery |
Warning |
N/A (N/A) |
ON |
This notification is generated when the two-way delay drops below the specified upper limit.
System impact
No impact on services.
Status control
Object
OID (object name) |
Index |
Type |
Value range |
MEP ID. |
N/A |
Integer32 |
Interger(1..8191) |
N/A |
Integer32 |
Integer(0..32767) |
N/A |
Integer32 |
Recommended action
No action is required.
hh3cCfdSlmStatistic
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.207.1.0.3 |
The one-way packet loss ratio exceeds the upper limit. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the two-way frame loss ratio on the source or target MEP reaches or exceeds the configured upper limit for three consecutive times.
System impact
Link congestion or packet loss occurs.
Status control
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.207.1.1.4 (hh3cCfdFrameEnd) |
N/A |
Integer32 |
nearEnd(1), farEnd(2) |
MEP ID. |
N/A |
Integer32 |
Interger(1..8191) |
N/A |
Integer32 |
Integer(0..32767) |
1.3.6.1.4.1.25506.2.207.1.1.5 (hh3cCfdStatisticThreshold) |
N/A |
OCTET STRING |
Recommended action
Check whether overloaded traffic exists in the network and whether a line issue exists.
hh3cCfdUnexpectedMDLevel
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.207.1.0.4 |
The MD levels are incorrect on the two ends. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the MD level in the received CCMs on the MEP is inconsistent with the configured level.
System impact
Continuity check cannot be performed.
Status control
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.207.1.1.6 (hh3cCfdMdIndex) |
MD index |
N/A |
Unsigned32 |
Unsigned32 (1..4294967295) |
1.3.6.1.4.1.25506.2.207.1.1.7 (hh3cCfdMdName) |
MD name |
N/A |
OCTET STRING |
OCTET STRING (SIZE(1..43)) |
1.3.6.1.4.1.25506.2.207.1.1.8 (hh3cCfdMaIndex) |
MA index |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.207.1.1.9 (hh3cCfdMaName) |
MA name |
N/A |
OCTET STRING |
OCTET STRING (SIZE(1..45)) |
MEP ID |
N/A |
Integer32 |
Interger(1..8191) |
Recommended action
Check CFD configuration on both ends to make sure the MD levels are consistent.
hh3cCfdMismerge
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.207.1.0.5 |
The MD or MA names are incorrect on the two ends. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the MD or MA names are inconsistent on the two ends that have consistent MD levels configured.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
MD index |
N/A |
Unsigned32 |
MD name |
N/A |
OCTET STRING |
MA index |
N/A |
Unsigned32 |
MA name |
N/A |
OCTET STRING |
MEP ID |
N/A |
Integer32 |
Interger(1..8191) |
Recommended action
Check CFD configuration on both ends to make sure the MD or MA names are consistent.
hh3cCfdLoc
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.207.1.0.6 |
The CCM connection times out. |
Error |
Critical |
1.3.6.1.4.1.25506.2.207.1.0.17 (hh3cCfdLOCClear) |
ON |
This notification is generated when the MEP fails to receive any CCM messages from the peer MEP upon expiration of the CCM timeout timer.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
MD index |
N/A |
Unsigned32 |
MD name |
N/A |
OCTET STRING |
MA index |
N/A |
Unsigned32 |
MA name |
N/A |
OCTET STRING |
MEP ID |
N/A |
Integer32 |
Interger(1..8191) |
1.3.6.1.4.1.25506.2.207.1.1.10 (hh3cCfdRMepId) |
Remote MEP ID |
N/A |
Unsigned32 |
Unsigned32 (1..8191) |
Recommended action
Check whether a link issue exists in the network.
hh3cCfdLOCClear
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.207.1.0.17 |
The MEPs on the two ends are reconnected. |
Recovery |
Warning |
N/A (N/A) |
ON |
This notification is generated when the MEP receives CCM messages from the peer MEP upon expiration of the CCM timeout timer.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
MD index |
N/A |
Unsigned32 |
MD name |
N/A |
OCTET STRING |
MA index |
N/A |
Unsigned32 |
MA name |
N/A |
OCTET STRING |
MEP ID |
N/A |
Integer32 |
Interger(1..8191) |
Remote MEP ID |
N/A |
Unsigned32 |
Recommended action
hh3cCfdUnexpectedMEP
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.207.1.0.7 |
The MEP IDs do not match on the two ends. |
Error |
Critical |
1.3.6.1.4.1.25506.2.207.1.0.15 (hh3cCfdUnexpectedMEPClear) |
ON |
This notification is generated when the MEP ID carried in CCMs is not in the MEP list on the local end if both MD level and MA name settings are correctly configured on the two ends.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
MD index |
N/A |
Unsigned32 |
MD name |
N/A |
OCTET STRING |
MA index |
N/A |
Unsigned32 |
MA name |
N/A |
OCTET STRING |
MEP ID |
N/A |
Integer32 |
Interger(1..8191) |
Recommended action
Check whether the two ends have the same MEP ID and MEP list settings.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.207.1.0.15 |
The local MEP receives a CCM with the same MEP ID from the remote MEP. |
Recovery |
Warning |
N/A (N/A) |
ON |
This notification is generated when the local MEP receives a CCM upon expiration of the CCM timeout timer, and the MEP ID in the received CCM matches the MEP list.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
MD index |
N/A |
Unsigned32 |
MD name |
N/A |
OCTET STRING |
MA index |
N/A |
Unsigned32 |
MA name |
N/A |
OCTET STRING |
MEP ID |
N/A |
Integer32 |
Interger(1..8191) |
Recommended action
hh3cCfdUnexpectedPeriod
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.207.1.0.8 |
The CCM intervals do not match. |
Error |
Critical |
1.3.6.1.4.1.25506.2.207.1.0.16 (hh3cCfdUnexpectedPeriodClear) |
ON |
This notification is generated when the CCM intervals do not match on the two ends that have correctly configured MD level, MA name, MEP ID, and MEP list settings.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
MD index |
N/A |
Unsigned32 |
MD name |
N/A |
OCTET STRING |
MA index |
N/A |
Unsigned32 |
MA name |
N/A |
OCTET STRING |
MEP ID |
N/A |
Integer32 |
Interger(1..8191) |
Remote MEP ID |
N/A |
Unsigned32 |
Recommended action
Check whether the two ends have the same CCM interval settings.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.207.1.0.16 |
The local MEP receives a CCM with the same CCM interval from the remote MEP. |
Recovery |
Warning |
N/A (N/A) |
ON |
This notification is generated when the local MEP receives a CCM with the same CCM interval from the remote MEP upon expiration of the CCM timeout timer.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
MD index |
N/A |
Unsigned32 |
MD name |
N/A |
OCTET STRING |
MA index |
N/A |
Unsigned32 |
MA name |
N/A |
OCTET STRING |
MEP ID |
N/A |
Integer32 |
Interger(1..8191) |
Remote MEP ID |
N/A |
Unsigned32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.207.1.0.9 |
The MEP receives a CCM with an abnormal port status TLV. |
Error |
Critical |
1.3.6.1.4.1.25506.2.207.1.0.19 (hh3cCfdExceptionMACStatusClear) |
ON |
This notification is generated when the local MEP receives a CCM from the remote MEP upon expiration of the CCM timeout timer, but the TLV information in the CCM indicates that the port status of the remote MEP is abnormal.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
MD index |
N/A |
Unsigned32 |
MD name |
N/A |
OCTET STRING |
MA index |
N/A |
Unsigned32 |
MA name |
N/A |
OCTET STRING |
MEP ID |
N/A |
Integer32 |
Interger(1..8191) |
Remote MEP ID |
N/A |
Unsigned32 |
Recommended action
Check the port status of the remote MEP.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.207.1.0.19 |
The local MEP receives a CCM with normal TLV information. |
Recovery |
Warning |
N/A (N/A) |
ON |
This notification is generated when the local MEP receives a CCM with normal TLV information from the remote MEP upon expiration of the CCM timeout timer.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
MD index |
N/A |
Unsigned32 |
MD name |
N/A |
OCTET STRING |
MA index |
N/A |
Unsigned32 |
MA name |
N/A |
OCTET STRING |
MEP ID |
N/A |
Integer32 |
Interger(1..8191) |
Remote MEP ID |
N/A |
Unsigned32 |
Recommended action
hh3cCfdRDI
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.207.1.0.10 |
The remote MEP receives a CCM carrying the RDI flag bits. |
Error |
Critical |
1.3.6.1.4.1.25506.2.207.1.0.18 (hh3cCfdRDIClear) |
ON |
This notification is sent to the local MEP after the remote MEP receives a CCM carrying the RDI flag bits.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
MD index |
N/A |
Unsigned32 |
MD name |
N/A |
OCTET STRING |
MA index |
N/A |
Unsigned32 |
MA name |
N/A |
OCTET STRING |
MEP ID |
N/A |
Integer32 |
Interger(1..8191) |
Remote MEP ID |
N/A |
Unsigned32 |
Recommended action
hh3cCfdRDIClear
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.207.1.0.18 |
The MEPs in the MA do not carry the RDI flag bits in CCMs. |
Recovery |
Warning |
N/A (N/A) |
ON |
This notification is sent to the local MEP after the remote MEP receives a CCM carrying no RDI flag bits.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
MD index |
N/A |
Unsigned32 |
MD name |
N/A |
OCTET STRING |
MA index |
N/A |
Unsigned32 |
MA name |
N/A |
OCTET STRING |
MEP ID |
N/A |
Integer32 |
Interger(1..8191) |
Remote MEP ID |
N/A |
Unsigned32 |
Recommended action
hh3cCfdAisDefectAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.207.1.0.11 |
The MEP receives AIS frames. |
Error |
Critical |
1.3.6.1.4.1.25506.2.207.1.0.12 (hh3cCfdAisDefectAlarmRecovery) |
ON |
This notification is generated when a MEP receives AIS frames and enters the AIS error state.
System impact
The link where the MEP resides is faulty.
Status control
Object
OID (object name) |
Index |
Type |
Value range |
MD index |
N/A |
Unsigned32 |
MD name |
N/A |
OCTET STRING |
MA index |
N/A |
Unsigned32 |
MA name |
N/A |
OCTET STRING |
MEP ID |
N/A |
Integer32 |
Interger(1..8191) |
Recommended action
Check the link errors on the two ends.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.207.1.0.12 |
The MEP no longer receives any AIS frames. |
Recovery |
Warning |
N/A (N/A) |
ON |
This notification is generated when a MEP receives no AIS frames within 3.5 times the AIS frame transmission interval.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
MD index |
N/A |
Unsigned32 |
MD name |
N/A |
OCTET STRING |
MA index |
N/A |
Unsigned32 |
MA name |
N/A |
OCTET STRING |
MEP ID |
N/A |
Integer32 |
Interger(1..8191) |
Recommended action
