02-HH3C-BFD-STD-MIB | 159.17 KB |
hh3cBfdVersionNumber(1.3.6.1.4.1.25506.2.72.1.1.1)
hh3cBfdSysInitMode(1.3.6.1.4.1.25506.2.72.1.1.2)
hh3cBfdSessNotificationsEnable(1.3.6.1.4.1.25506.2.72.1.1.3)
hh3cBfdSessNumberLimit (1.3.6.1.4.1.25506.2.72.1.1.4)
hh3cBfdSessionActive (1.3.6.1.4.1.25506.2.72.1.1.5)
hh3cBfdSessName (1.3.6.1.4.1.25506.2.72.3.1)
hh3cBfdLocalAddr (1.3.6.1.4.1.25506.2.72.3.3)
hh3cBfdRemoteAddr (1.3.6.1.4.1.25506.2.72.3.4)
hh3cBfdIfName (1.3.6.1.4.1.25506.2.72.3.5)
hh3cBfdSessType (1.3.6.1.4.1.25506.2.72.3.6)
hh3cBfdVrfIndex (1.3.6.1.4.1.25506.2.72.3.7)
hh3cBfdDiscrAuto (1.3.6.1.4.1.25506.2.72.3.8)
hh3cBfdSessVsiPeerAddr (1.3.6.1.4.1.25506.2.72.3.9)
hh3cBfdSessVsiName (1.3.6.1.4.1.25506.2.72.3.10)
hh3cBfdSessDefaultIp (1.3.6.1.4.1.25506.2.72.3.11)
hh3cBfdSessNextHop (1.3.6.1.4.1.25506.2.72.3.12)
hh3cBfdSessPWSecondaryFlag (1.3.6.1.4.1.25506.2.72.3.13)
hh3cBfdSessVcId (1.3.6.1.4.1.25506.2.72.3.14)
hh3cBfdLocalDiscr (1.3.6.1.4.1.25506.2.72.3.15)
HH3C-BFD-STD-MIB
About this MIB
Upper layer protocols implement fast fault detection through the link layer. The fault detection time varies by link type, and failures might not be detected sometimes. POS has the fastest detection speed of approximately 50 milliseconds, which is used to measure fault detection time for other protocols.
BFD provides a general-purpose, standard, medium- and protocol-independent fast failure detection mechanism. BFD can uniformly and quickly detect the failures of the bidirectional forwarding paths between two devices for upper-layer protocols such as routing protocols and MPLS. BFD can provide detection measured in milliseconds, which is close to the detection time implemented by POS.
This document describes the following variables required to implement BFD:
● hh3cBfdGlobalObjects includes hh3cBfdVersionNumber (version number), hh3cBfdSysInitMode (session initialization mode), hh3cBfdSessNotificationsEnable (SNMP notifications switch), and hh3cBfdSessNumberLimit (session limit).
● hh3cBfdIfTable describes BFD interface information.
● hh3cBfdSessTable describes BFD session information.
● hh3cBfdSessStatTable describes BFD session statistics information.
● hh3cBfdSessPerfTable describes BFD session performance information.
● In hh3cBfdNotifications, hh3cBfdSessStateChange describes session state changes (from up to another state, or from another state to up), and hh3cBfdSessAuthFail describes authentication failure information.
HH3C-BFD-STD-MIB is based on draft-ietf-bfd-base-04.txt. This MIB is used for network management protocols in the Internet communities. It describes the objects used to configure or monitor bidirectional forwarding on devices supporting BFD.
MIB file name
hh3c-bfd-std.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cBfdMIB(72)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdVersionNumber(1.3.6.1.4.1.25506.2.72.1.1.1) |
read-only |
Unsigned32 |
Standard MIB values. |
Version number. |
Not supported |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdSysInitMode(1.3.6.1.4.1.25506.2.72.1.1.2) |
read-write |
INTEGER |
active(1), passive(2) |
Mode for establishing a BFD session. |
Not supported |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdSessNotificationsEnable(1.3.6.1.4.1.25506.2.72.1.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Whether SNMP notifications is enabled. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdSessNumberLimit (1.3.6.1.4.1.25506.2.72.1.1.4) |
read-only |
Unsigned32 |
Active session limit. |
Not supported |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdSessionActive (1.3.6.1.4.1.25506.2.72.1.1.5) |
read-only |
Unsigned32 |
Total active session count. |
Supports only the read operation. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdSessName (1.3.6.1.4.1.25506.2.72.3.1) |
accessible-for-notify |
OCTET STRING (0..64) |
Standard MIB values. No value is displayed if the session name does not exist. |
Session name. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdLocalAddr (1.3.6.1.4.1.25506.2.72.3.3) |
DisplayString |
OCTET STRING (0..255) |
Source address of the session. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdRemoteAddr (1.3.6.1.4.1.25506.2.72.3.4) |
DisplayString |
Destination address of the session. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdIfName (1.3.6.1.4.1.25506.2.72.3.5) |
DisplayString |
Name of the interface associated with the session. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdSessType (1.3.6.1.4.1.25506.2.72.3.6) |
INTEGER |
static(1), dynamic(2) |
BFD session type. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdVrfIndex (1.3.6.1.4.1.25506.2.72.3.7) |
Unsigned32 |
Unsigned32(0..4294967295) |
Index of the VPN associated with the session. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdDiscrAuto (1.3.6.1.4.1.25506.2.72.3.8) |
TruthValue |
true(1), false(2) The default value is false. |
Whether to automatically assign discriminator values to the BFD session. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdSessVsiPeerAddr (1.3.6.1.4.1.25506.2.72.3.9) |
DisplayString |
Peer address of the VSI instance associated with the BFD session, which applies only to the LSP session carrying the FEC information and whose type is BFD_FEC_EVPN_PSEUDOWIRE. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdSessVsiName (1.3.6.1.4.1.25506.2.72.3.10) |
OCTET STRING (0..31) |
Standard MIB values. No value is displayed if the VSI name does not exist. |
Name of the VSI instance associated with the BFD session. The name can be obtained by VsiIndex. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdSessDefaultIp (1.3.6.1.4.1.25506.2.72.3.11) |
TruthValue |
true(1), false(2) |
Whether the BFD session uses a multicast address as the peer IP address. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdSessNextHop (1.3.6.1.4.1.25506.2.72.3.12) |
DisplayString |
Next hop IP address of the LSP detected by the BFD session. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdSessPWSecondaryFlag (1.3.6.1.4.1.25506.2.72.3.13) |
INTEGER |
flagMasterPW(1), flagSecondaryPW(2), flagNoPW(3) |
Role of PW associated with the BFD session. (In uiEntryKey, the second bit is used to distinguish the primary and backup PWs.) |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdSessVcId (1.3.6.1.4.1.25506.2.72.3.14) |
Unsigned32 |
Unsigned32 (0..4294967295) |
VC ID of the PW associated with the BFD session (uiPWID for FEC). |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdLocalDiscr (1.3.6.1.4.1.25506.2.72.3.15) |
Unsigned32 |
Unsigned32 (1..4294967295) |
Local discriminator that uniquely identifies a BFD session. |
As per the MIB. |
Tabular objects
hh3cBfdIfTable
About this table
This table contains information about the interface enabled with BFD.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3cBfdIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdIfIndex(1.3.6.1.4.1.25506.2.72.1.2.1.1) |
InterfaceIndex |
Integer32(1..2147483647) |
Index of the interface enabled with BFD. |
As per the MIB. |
hh3cBfdIfDesiredMinTxInterval(1.3.6.1.4.1.25506.2.72.1.2.1.2) |
read-write |
BfdInterval |
Unsigned32(1..4294967295) |
Minimum interval for transmitting BFD control packets. |
hh3cBfdIfDesiredMinRxInterval(1.3.6.1.4.1.25506.2.72.1.2.1.3) |
read-write |
BfdInterval |
Minimum interval for receiving BFD control packets. |
hh3cBfdIfDetectMult(1.3.6.1.4.1.25506.2.72.1.2.1.4) |
read-write |
Unsigned32 |
Detection time multiplier for control packet mode. |
hh3cBfdIfAuthType(1.3.6.1.4.1.25506.2.72.1.2.1.5) |
read-only |
INTEGER |
none(1), simple(2), md5(3), mmd5(4), sha1(5), msha1(6). The default value is none. |
BFD authentication mode for BFD control packets. |
As per the MIB. |
hh3cBfdSessTable
About this table
This table contains BFD session information.
Read:Supported
Columns
The table index is hh3cBfdSessIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdSessIndex (1.3.6.1.4.1.25506.2.72.1.3.1.1) |
BfdSessIndexTC |
Session index that uniquely identifies a session. |
As per the MIB. |
hh3cBfdSessIfIndex (1.3.6.1.4.1.25506.2.72.1.3.1.2) |
read-only |
InterfaceIndexOrZero |
Integer32 (0..2147483647) |
Index of the interface where the BFD session resides. |
As per the MIB. |
hh3cBfdSessAppSupportId(1.3.6.1.4.1.25506.2.72.1.3.1.3) |
read-only |
Hh3cAlarmStatus |
BITS { none(0), ospf(1), isis(2), bgp(3), mpls(4) } |
Upper-layer protocols supported by the BFD session. |
As per the MIB. |
hh3cBfdSessLocalDiscr(1.3.6.1.4.1.25506.2.72.1.3.1.4) |
read-only |
Unsigned32 |
Local discriminator of the BFD session, which is a unique non-zero value. |
As per the MIB. |
hh3cBfdSessRemoteDiscr(1.3.6.1.4.1.25506.2.72.1.3.1.5) |
read-only |
Unsigned32 |
Remote discriminator of the BFD session. The initial value is 0. |
As per the MIB. |
hh3cBfdSessDstPort(1.3.6.1.4.1.25506.2.72.1.3.1.6) |
read-only |
InetPortNumber |
Standard MIB values. The default value is 3784. |
UDP port number of the BFD session. |
As per the MIB. |
hh3cBfdSessOperMode(1.3.6.1.4.1.25506.2.72.1.3.1.7) |
read-only |
INTEGER |
asynchModeWOEchoFun(1), demandModeWOEchoFunction(2), asyncModeWEchoFun(3), demandModeWEchoFunction(4). The default value is asynchModeWOEchoFun. |
BFD session mode. |
As per the MIB. |
hh3cBfdSessAddrType(1.3.6.1.4.1.25506.2.72.1.3.1.8) |
read-only |
InetAddressType |
INTEGER{ unknown(0), ipv4(1), ipv6(2), dns(16) } |
IP address type of the interface where the BFD session resides. |
As per the MIB. |
hh3cBfdSessLocalAddr(1.3.6.1.4.1.25506.2.72.1.3.1.9) |
read-only |
InetAddress |
IP address of the interface where the BFD session resides. |
As per the MIB. |
hh3cBfdSessRemoteAddr(1.3.6.1.4.1.25506.2.72.1.3.1.10) |
read-only |
InetAddress |
IP address of the interface that receives BFD packets. |
As per the MIB. |
hh3cBfdSessLocalDiag(1.3.6.1.4.1.25506.2.72.1.3.1.11) |
read-only |
BfdDiag |
noDiagnostic(1), controlDetectionTimeExpired(2), echoFunctionFailed(3), neighborSignaledSessionDown(4), forwardingPlaneReset(5), pathDown(6), concatenatedPathDown(7), administrativelyDown(8), reverseConcatenatedPathDown(9). The default value is noDiagnostic. |
Diagnosis code that indicates the most recent BFD session state change reason. |
As per the MIB. |
hh3cBfdSessState(1.3.6.1.4.1.25506.2.72.1.3.1.12) |
read-only |
INTEGER |
adminDown(0), down(1), init(2), up(3), The default value is DOWN. |
Current state of the BFD session. |
As per the MIB. |
hh3cBfdSessControlPlanIndepFlag(1.3.6.1.4.1.25506.2.72.1.3.1.13) |
read-only |
TruthValue |
true(1), false(2). The default value is false. |
Whether the BFD session can operate independently of the control plane. |
As per the MIB. |
hh3cBfdSessAuthFlag(1.3.6.1.4.1.25506.2.72.1.3.1.14) |
read-only |
TruthValue |
Flag that indicates whether the BFD session requires authentication. |
As per the MIB. |
hh3cBfdSessDemandModeFlag(1.3.6.1.4.1.25506.2.72.1.3.1.15) |
read-only |
TruthValue |
Whether the BFD session supports the Demand mode. |
As per the MIB. |
About this table
This table contains BFD packet statistics information.
Read:Supported
Columns
This table does not contain indexes.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdSessStatPktInHC(1.3.6.1.4.1.25506.2.72.1.4.1.1) |
read-only |
Counter64 |
INTEGER(0..18446744073709551615) |
Number of received BFD packets. |
Not supported |
hh3cBfdSessStatPktOutHC(1.3.6.1.4.1.25506.2.72.1.4.1.2) |
read-only |
Counter64 |
Number of sent BFD packets. |
Not supported |
hh3cBfdSessStatDownCount(1.3.6.1.4.1.25506.2.72.1.4.1.3) |
read-only |
Counter32 |
INTEGER(0..4294967295) |
Number of times the BFD session has entered down state since the most recent reboot of the system. |
Not supported |
hh3cBfdSessStatPktDiscard(1.3.6.1.4.1.25506.2.72.1.4.1.4) |
read-only |
Counter64 |
Number of BFD control packets discarded by the receiver since the most recent reboot of the system. |
Not supported |
hh3cBfdSessStatPktLost(1.3.6.1.4.1.25506.2.72.1.4.1.5) |
read-only |
Counter64 |
Number of BFD control packets failed to be sent since the most recent reboot of the system. |
Not supported |
About this table
This table contains performance information about a BFD session.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBfdSessPerfCreatTime(1.3.6.1.4.1.25506.2.72.1.5.1.1) |
read-only |
TimeStamp |
TimeTicks |
System time when the BFD session was created. |
Not supported |
hh3cBfdSessPerfLastUpTime(1.3.6.1.4.1.25506.2.72.1.5.1.2) |
read-only |
TimeStamp |
TimeTicks |
System time when the BFD session entered up state. |
Not supported |
hh3cBfdSessPerfLastDownTime(1.3.6.1.4.1.25506.2.72.1.5.1.3) |
read-only |
TimeStamp |
TimeTicks |
System time when the BFD session entered down state. |
Not supported |
Notifications
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.72.0.1 |
The BFD session state changes. |
Informational |
Warning |
ON |
Notification triggers
This notification is generated when the BFD session changes from Up to another state, or changes to Up from another state.
The BFD session changes from Up to another state for one of the following reasons:
The path detected by BFD fails, and BFD packets cannot be correctly exchanged as a result.
The interface bound to the BFD session goes down.
Other BFD sessions bound to the session go down.
The BFD session on the remote end is shut down or deleted.
The BFD session changes to Up from another state for one of the following reasons:
The BFD session changes to Up from Down when it is established or recovers from failures.
The BFD session changes to Up from Init when it is established or recovers from failures.
The BFD session changes to Up from AdminDown when its configuration changes.
The BFD session changes to AdminDown from another state when it is deleted.
System impact
If the BFD session changes to Down from another state, the session is abnormal, and the upper-layer application will be affected.
If the BFD session changes to Up from another state, the session recovers, and the upper-layer application will also recover.
The following state changes of the BFD session have no impact on services:
Down from Init.
Init from Down.
AdminDown from Down/Init/Up.
Enabling the notifications will greatly consume CPU resources if a large number of BFD sessions have state changes.
Status control
ON
CLI: Use the snmp-agent trap enable bfd command.
OFF
CLI: Use the undo snmp-agent trap enable bfd command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.72.1.3.1.2 (hh3cBfdSessIfIndex) |
hh3cBfdSessIndex |
1.3.6.1.4.1.25506.2.72.1.3.1.1 (hh3cBfdSessIndex) |
Session index. |
hh3cBfdSessIndex |
BfdSessIndexTC |
1.3.6.1.4.1.25506.2.72.1.3.1.12 (hh3cBfdSessState) |
Session state. |
hh3cBfdSessIndex |
INTEGER |
adminDown(0), down(1), init(2), up(3) |
Recommended action
To resolve this issue:
1.Identify whether the BFD session changes to Down from another state.
- If yes, proceed to step 2.
- If no, no action is required.
2.Use the display interface interface-type interface-number command to identify whether the interface bound to the session in Up state.
- If yes, proceed to step 3.
- If no, connect the physical link correctly and use the display bfd session command to view the session state. If the value for the State field is not Up, proceed to step 3.
3.Use the display bfd session command to identify whether the BFD sessions on the two ends are deleted.
- If yes, configure the session on the two ends correctly and use the display bfd session command to view the session state. If the value for the State field is not Up, proceed to step 4.
- If no, proceed to step 4.
4.Use the ping command to identify whether the forwarding path can forward packets correctly.
- If yes, proceed to step 5.
- If no, re-deploy the forwarding path and use the display bfd session command to view the session state. If the value for the State field is not Up, proceed to step 5.
5.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cBfdSessAuthFail
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.72.0.2 |
The BFD session authentication fails. |
Error |
Major |
ON |
This notification is generated when the BFD session authentication fails.
Possible reasons for this notification include:
Authentication settings are configured on only one end of the BFD session.
Authentication settings are inconsistent on two ends of the BFD session.
The link between the two ends is faulty.
System impact
The BFD session cannot come up and the upper-layer application will be affected.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.72.1.2.1.1 (hh3cBfdSessIfIndex) |
hh3cBfdSessIndex |
Recommended action
1.Use the display current-configuration command to identify whether the authentication settings on the two ends of the BFD session are consistent.
- If no, reconfigure the authentication settings and use the display bfd session command to view the session state. If the value for the State field is not Up, proceed to step 2.
2.Examine whether the two ends are connected correctly.
- If no, connect the two ends correctly and use the display bfd session command to view the session state. If value for the State field is not Up, proceed to step 3.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cBfdSessStateUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.72.0.3 |
The BFD session comes up. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the BFD session comes up.
System impact
When the BFD session comes up, the associated services will recover.
Enabling the notifications will greatly consume CPU resources if a large number of BFD sessions come up.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
hh3cBfdSessIndex |
Session index. |
hh3cBfdSessIndex |
BfdSessIndexTC |
Session state. |
hh3cBfdSessIndex |
INTEGER |
1.3.6.1.4.1.25506.2.72.3.1 (hh3cBfdSessName) |
Session name. |
N/A |
Standard MIB values., No value is displayed if the session name does not exist. |
1.3.6.1.4.1.25506.2.72.3.2 (hh3cBfdVpnInstanceName) |
Name of the VPN to which session is bound. |
N/A |
Standard MIB values., No value is displayed if the session is not bound to any VPNs. |
1.3.6.1.4.1.25506.2.72.3.3 (hh3cBfdLocalAddr) |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.72.3.4 (hh3cBfdRemoteAddr) |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.72.3.5 (hh3cBfdIfName) |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.72.1.3.1.11 (hh3cBfdSessLocalDiag) |
Diagnosis code that specifies the reason for the previous session state change in the local system. |
hh3cBfdSessIndex |
INTEGER(1..31) |
noDiagnostic(1), controlDetectionTimeExpired(2), echoFunctionFailed(3), neighborSignaledSessionDown(4), forwardingPlaneReset(5), pathDown(6), concatenatedPathDown(7), administrativelyDown(8), reverseConcatenatedPathDown(9),, The default value is noDiagnostic. |
1.3.6.1.4.1.25506.2.72.3.6 (hh3cBfdSessType) |
BFD session type. |
N/A |
INTEGER |
BFD session type. Options include the following: , static(1)—Static session., dynamic(2)—Dynamic session. |
1.3.6.1.4.1.25506.2.72.3.7 (hh3cBfdVrfIndex) |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.72.3.8 (hh3cBfdDiscrAuto) |
N/A |
TruthValue |
Options include the following: , true (1)—Enables automatic assignment of discriminators., false (2)—Disables automatic assignment of discriminators., The default value is false. |
1.3.6.1.4.1.25506.2.72.3.9 (hh3cBfdSessVsiPeerAddr) |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.72.3.10 (hh3cBfdSessVsiName) |
N/A |
Standard MIB values., No value is displayed if the VSI name does not exist. |
1.3.6.1.4.1.25506.2.72.3.11 (hh3cBfdSessDefaultIp) |
N/A |
TruthValue |
Options include the following: , true (1)—Uses a multicast address as the peer IP address., false (2)—Does not use a multicast address as the peer IP address. |
1.3.6.1.4.1.25506.2.72.3.12 (hh3cBfdSessNextHop) |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.72.3.13 (hh3cBfdSessPWSecondaryFlag) |
N/A |
INTEGER |
Options include the following: , flagMasterPW(1)—Primary PW., flagSecondaryPW(2)—Backup PW., flagNoPW(3)—No PW is associated. |
1.3.6.1.4.1.25506.2.72.3.14 (hh3cBfdSessVcId) |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.72.3.15 (hh3cBfdLocalDiscr) |
N/A |
Unsigned32 |
Recommended action
No action is required.
hh3cBfdSessStateDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.72.0.4 |
The BFD session goes down. |
Error |
Critical |
N/A (N/A) |
ON |
This notification is generated when the BFD session goes down.
System impact
The BFD session state is abnormal, and the upper-layer application will be affected.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
hh3cBfdSessIndex |
Session index. |
hh3cBfdSessIndex |
BfdSessIndexTC |
Session state. |
hh3cBfdSessIndex |
INTEGER |
Session name. |
N/A |
N/A |
N/A |
DisplayString |
N/A |
DisplayString |
N/A |
DisplayString |
hh3cBfdSessIndex |
INTEGER(1..31) |
BFD session type. |
N/A |
INTEGER |
N/A |
Unsigned32 |
N/A |
TruthValue |
N/A |
DisplayString |
N/A |
N/A |
TruthValue |
N/A |
DisplayString |
N/A |
INTEGER |
N/A |
Unsigned32 |
N/A |
Unsigned32 |
Recommended action
1.Use the display interface interface-type interface-number command to identify whether the interface bound to the session is in Up state.
- If no, connect the physical link correctly and identify whether the hh3cBfdSessStateUp notification is generated. If the notification is not generated, proceed to step 2.
2.Use the display bfd session command to identify whether the BFD sessions on the two ends are deleted or shutdown.
- If the value for the State field is AdminDown, the session has been deleted or shut down. Reconfigure the session on the two ends correctly and identify whether the hh3cBfdSessStateUp notification is generated. If the notification is not generated, proceed to step 3.
- If the value for the State field is Down, proceed to step 3.
3.Use the ping command to identify whether the forwarding path can forward packets correctly.
- If yes, re-deploy the forwarding path and identify whether the hh3cBfdSessStateUp notification is generated. If the notification is not generated, proceed to step 4.
4.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cBfdSessReachLimit
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.72.0.5 |
The number of BFD sessions has reached the upper limit. |
Informational |
Critical |
N/A (N/A) |
ON |
This notification is generated when the number of BFD sessions has reached the upper limit on the device.
You have created new BFD sessions after the number of BFD sessions reached the upper limit.
The number of dynamic BFD sessions has exceeded the upper limit.
System impact
You cannot create new BFD sessions after the number of BFD sessions has reached the upper limit on the device.
As a best practice, do not perform the power cycling or reset operation for the device that generates the notification. The operation will result in resource reallocation that affects services.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.72.1.1.4 (hh3cBfdSessNumberLimit) |
Upper limit of BFD sessions. |
N/A |
Unsigned32 |
Recommended action
To resolve the issue:
1.Stop creating new BFD sessions.
2.Delete unnecessary BFD sessions. For example, use the undo ospf bfd enable command to delete unnecessary BFD sessions associated with OSPF. For the methods of deleting BFD sessions associated with other features, see the corresponding command references.
